Originally posted by Class A If you had an FF camera, you would just stop down your lens accordingly to get the same DOF as you are getting with APS-C.
In other words, there is no "deeper DOF" advantage for APS-C (unless you go into f/22 territory).
Regarding metering, I'd really like a "highlight protection" mode that exposes in such a way that the brightest parts in the image do not get blown out. This would support the "ETTR" (expose to the right) approach that works well for me as I'm always post-processing anyhow.
It would be acceptable to me, if the camera adjusted the metering based on prior shots of the same scene, evaluating the actual sensor data, which is more accurate than just relying on the metering chip.
Thanks, Class A for correcting my typo. I was typing away speedily without even thinking, I meant the focal length perspective not DOF I get from a 58mm lens instead of longer lens where the perspective is compressed. The whole issue of equivalence and DOF between FF vs APSC has been discussed to death which I don't real subscribe to that much except that the fact is if I use a FF lens on APSC sensor, I get the same as FF lens on FF sensor, but mine is already cropped in the camera whereas with FF, they have to do it in post processing or they use longer focal length lens.
I agree with you that I chimp a lot with the initial shots (usually TAv mode) and then settle in M mode for the remainder of the shots.
---------- Post added 03-01-2015 at 11:01 AM ----------
Originally posted by derekkite Yes they are. So spot metering is very dramatic on the K3. Very easy to meter on a small white spot. I often spot meter on the brightest part, hit ae-l to fix the exposure, recompose and shoot. That may work for you.
I am with you on this... but my thumb is usually on the AF button on the back of the camera and in the heat of the moment, I could bother with the AE-L button; but you're right, I will do that in the first shots while I am chimping.
