Originally posted by JimmyDranox
I can't say exactly about this piece, but from my experience, adapters for spotting scopes have a different barrel than 1,25'' or 2'' which are standard for telescopes. What I can see from specifications, is that this adapter is in fact a projection lens. And with 12.5 fix aperture (focal/diameter ratio), and magnification included, I wouldn't recommend it for use with anything other than Pentax spotting scopes.
With the adapter set up I have described before, you will have the native F/D ratio of the telescope, which can be much faster for some of them. And you can modify it with the help of a Barlow lens.
What kind of mirror scope did you have?
If you're referring to me, I don't have a mirror scope (I have the PF-80EDA). I was bringing up the PF-CA35 in case it might be usable by the original poster.
The PF-CA35 has the same diameter barrel as the eyepieces for the Pentax PF-65ED, PF-80ED and PF-100ED scopes, i.e., the XW and XF series eyepieces, which have a barrel diameter of 1.25 inches.
