Originally posted by boriscleto
It has a pop-up flash, PentaxIsDooomed™
It doesn't have a pop-up flash, PentaxIsDooomed™
No, of course Pentax isn't doomed because of the K-3ii having or not having a pop-up-flash.
It's just that the K-3ii will have another issue giving it a harder time standing against e.g. the Nikon D7200, which wouldn't have been necessary. I assume the tiny flash lights are cheap, so that it's not about costs.
The resolution enhancement thing doesn't set off much, because essentially it is for indoor stills use only.
Outdoors in the wind, too many things move all the time (leaves, twigs, flowers, clouds, water surfaces), which would introduce severe false color artefacts all over the image, as R/G/B channels would be recorded at different times.
Even long distance objects wobble slightly all the time due to atmospheric turbulences. I'm not talking about photography in deserts or canyons, also astro photographers know about this.
But it'll be fine for photographing test targets at home
I'm 100% confident that we'll se a lot of crops from the inner area of Siemens stars.
