Originally posted by IchabodCrane A little bit of misrepresentation on this one. Almost all m4/3 cameras without built-in flash come with a very small clip on flash that is powered by the camera, not batteries. You could probably attach those things to your camera strap if you really wanted to.
---------- Post added 04-24-15 at 07:23 AM ----------
I think you found the reason for GPS instead of flash on the K-3.2. The pixel-shift technology is the unique feature of this camera and one that would more commonly dovetail with GPS data than with a built-in flash.
Still, this doesn't make total sense to me though I suppose any combination might not. I fully understand the advantage of embedding the GPS data into the image file and you can't do that with geotracking/software solutions (in most cases, I think). However, Ricoh already provided a solution for this as long as you wanted to shell out $200. Sure, you can't put their GPS unit on the camera and use a flash at the same time but that's a combined need that might present itself three times in the life of the camera. It's a very rare situation where you'd truly want or need both. The fact remains GPS is not a photographic tool whereas built-in flash can be.
But here comes another aspect into play: these mirrorless cameras have a rated battery life of around 350 images, CIPA for either O E-M1, S A7, Fuji X-T1... Without flash! Now having an on board powered flash might... Now, K-3II CIPA 720 images. Just an additional thought which fieldguys might consider...
And that's where the K-3II is positioned, field camera. I work in archaeology, you can imagine how perfect this tool is for our fieldwork. As it might be for any profession being out and getting images at different locations. And, yes, before that it was impossible to use the geolocation, standard with the ogps, and a flash at the same time, which was not so rare as some want to believe...
