Originally posted by jaad75 I use, actually. I don't like smartphones at all.
And nobody can track me if I don't want to...
OK, new here (have been reading for a while and I guess I should post in the newcomers forum but hey ho..) - a GPS unit in a camera or phone is a receiver only - you cannot be tracked unless you install software on your phone that actually sends your location somewhere. You
can be tracked (within limits) by the cell signal - if you're in range of a cell tower, though this is nowhere near as accurate as GPS, and this works with phones with or without a GPS (so not just smartphones).
On topic:-)
- I've been tagging with a separate GPS and Lightroom for years. It's pretty easy, you don't get the direction and you do have to be disciplined about the time set on the camera if you want it to be as quick as possible. But it's not a major pain. Having said, that I don't object to not having to do it (and getting a bit more information).
- You can use your phone but on some platforms the apps are limited (and the battery will not last long) - a dedicated GPS or GPS logger is better for this, especially if you're doing it for long periods.
- I've also got an O-GPS1 which in principle simplifies things, but in practice I find it often doesn't tag locations of all pictures if your usual practice is to turn the camera off. It takes longer to re-aquire location than the time taken between turning the camera on and taking a picture (not long, a couple of seconds or so). So it tends to miss the first one/few and I'd be interested to know, when it's out, if the K3-II does this too.
- I got the O-GPS1 for Astrotracer, and it works but is touchy/unreliable (though probably no more so than getting a proper tracking mount working well and, within it's limits, it's much smaller/cheaper/convenient.
- I do use the onboard flash every now and again, for fill and 'record' shots, but probably wouldn't miss it. My wife and older children, who often use my K5 as a big point and shoot ,would though (I suppose, if I decide to get one, this is an excuse to keep the K5...)
- I used to think that I knew where I took every picture too, until I went back though early scanned slides - most yes, all roughly, but there are still some that annoy me because I haven't worked it out yet.
- Of course you can edit RAW files - you can edit any files (you might break digital signatures etc., but you can still do it). It's just that the philosophy of modern PP software is 'non-destructive editing' which you can always undo, so leaving the actual image data untouched makes sense.
