Originally posted by Rorschach
And what exactly is stopping you from doing both pixel shifting each shot and stitching several into a hyper-resolution panorama? I get it: nothing...you just want to cast a bad light on this.
Also, in the first point you argue that there is no need for extra resolution, yet in the very next one you argue for more, using panorama...
Straight question: what is your agenda here?
I have no particular agenda, I just feel that the new K3-II bring almost nothing a bit like the new K5-II did bring almost nothing. At least the K5-IIs did remove the low pass filter an increase in sharpness that applied to all shoots. This applied to all shoots. Not a few ones.
As for arguing for more resolution, I simply explain how somebody that want it can get it if needed. Not limited to better 24MP, but ilimited basically.
The thing is sticking a panorama is something you can do with you current camera (even your smartphone again). It can be very easy just take a cheap tele and do it, it can even be done handled for simple cases. While I still think this most often not necessary and bothersome you can get a 50MP in a few seconds by just stiching 3 shots.
The technique work will moving subjects if they are not part of several pictures, it allow for very shallow deph of field (brenizer), almost unlimited resolution if your tele is long enough and also allow to have wider angle of view than what your lens permit. It open possibility for virtual tours and 360° viewing.
While panorama stiching is still bothersome and limited in its use, it's potential applications are much broader and effective.
The K3-II (or K3) could have included the software to make panorama in its firmware offering much broader application spectrum. It could have improved the flash so it could effectively replaced a basic cobra dedicated flash in most situations, making it innovative and clearly distinguish itself.
Instead we get geotagging, astro tracer and better 24MP while on a tripod.
