06-22-2015, 01:55 PM - 1 Like   #916
kenspo's Avatar
QuoteOriginally posted by Nicolas06 Quote
My understanding by reading all that is the AF improvements in K3-II are negligible compared to the performance of K3 and that there still room for improvement compared to Canikon. A thing to remember for somebody that want to invest that much in telephotos lenses
Well, it's not! The difference is VERY noticeable.
06-22-2015, 02:02 PM   #917
Kenneth, just to be clear: were you able to personally see such a difference? If so, in which areas? Could you say a few words on this subject? I'll forward them to a fellow Pentaxian worried about Pentaxforums (lack of) findings
Thank you.
06-22-2015, 02:14 PM   #918
kenspo's Avatar
I take pictures at rock and metal concerts. So you can imagine..difficult light, moving objects and a lot of smoke!
06-22-2015, 04:39 PM   #919
Shanti's Avatar
QuoteOriginally posted by kenspo Quote
yes that quote from PF review was a bit strange?? is the AF-C tracking better than K3?? main use for birds with my 150-450, even on my K5II is seems better than the DA*300 for tracking
06-22-2015, 06:49 PM   #920
QuoteOriginally posted by Shanti Quote
Every review from PF on new bodies says that the autofocus is marginally better. I don't pay attention to that anymore. Better is very hard to define, and what someone experiences with a wide zoom or normal prime is different from what someone shooting at 300-500 mm experiences.
The way I look at it is the number of hits as a percentage. If I can get another 5% of the shots in focus, that is an improvement, which means 20 shots more in a typical 400 shot session. This morning 356 photos 302 were in focus. What would improve the numbers is faster tracking. I got about 1/3 bird in flight in focus. AFC, Hold at 4. Back button AF. When the light improved the hit rate went up substantially.
If the K3II is better than the K3, I'm interested. The 1.21 made a big difference for me, getting rid of almost all the missed focus situations, and improved the tracking.
But, and a big but, if the AF is improved I will start attempting more difficult shots, probably increasing my miss rate. That already has happened with 1.21.
06-22-2015, 09:11 PM   #921
kenspo's Avatar
I haven't tried it on flying birds, running animals etc. But in my working environment, the miss rate has dropped a lot. Still behind the others, but we're going the right way!
06-22-2015, 10:31 PM   #922
Well because you see a huge difference and Pentax forum see none on this K3-II could you maybe put some numbers behind? Like with K3 on a concert I shoot X pictures, Y are out of focus... with K3-II, I shoot X', Y' are out of focus... That's an improvement for my practice of Z% ?
I say that because I find it a bit strange to have yourself that the difference is VERY noticable and PF that say there is none visible. With actual number or at least more elaborate response we can better understand how substantive it is.
You know "VERY noticable" is a bit fuzzy. I would think VERY noticable would be like faillure rate divided by 2 but derekkite more or less explained that just a small increase could be "VERY noticable" for him... (or something like that). Out of 400 shoots... But sure for Pentax forum out of maybe 20 shoots they didn't see anything.
The "VERY noticable" of some can be the "negligible" of others. That's the issue with qualitative qualifiers.
06-23-2015, 12:28 AM   #923
One way of testing the AF would be to have both cameras to be tested mounted side by side with the same type of lenses. Both firing away simultaneously with AFC and all AF points active.
Let a kid run around in front of the cameras. Then compare the results. Would be interesting.
06-23-2015, 05:42 AM   #924
Hint: they were likely shooting:
(a) different scenes;
(b) different events;
(c) different lenses;
(d) different camera settings;
(e) different levels of shooting experience.
You want overly simple answers for complicated questions.
---------- Post added 2015-06-23 at 10:46 PM ----------
QuoteOriginally posted by Gimbal Quote
That's about what is needed - comparable testing under comparable circumstances, leaving the only variable the behaviour of the camera. Not highly variable testing under highly variable conditions.
06-23-2015, 06:25 AM   #925
Testing is almost impossible to do in a way that would be useful. Each lens in a very wide suite of conditions and light. A fixed body would tell us little how it would focus in someone's hands. Subjective comments with some clues as to the circumstances is useful.
Kenspo, did you try the K3 with 1.20 to compare? I noticed the center point characteristics changed with that firmware upgrade. Changed slightly for the worse while the general experience changed for the better.
06-23-2015, 06:32 AM   #926
QuoteOriginally posted by derekkite Quote
I honestly cannot say that I've noticed such a change for the worse with the K3 + DA560mm (nor a change for the better though) In what way do you feel it is worse?
Chris
06-23-2015, 08:14 AM   #927
RockvilleBob's Avatar
A recent positive review of the K3 II
Pentax K-3 II Review | PhotographyBLOG
06-23-2015, 08:46 AM   #928
colodion's Avatar
QuoteOriginally posted by totsmuyco Quote
Those are nice shots. Can you post some unedited low light high ISO shots? It would be mice to know how this camera handles noise.
A high isos there is an improvement compared to k3 and almost equals the k5IIs.
In this thread there are benchmarks.
The page is in spanish.
K3-K3II-K5IIs Comparativa RD y ruido mas fotos k3 - Pentaxeros.com
The parrot is in the shade and ISO 2200 plumage very well appreciated
06-23-2015, 12:27 PM   #929
Matthew Saville's Avatar
Subjective testing is what I get paid to do, and having used pretty much every Canon & Nikon DSLR since day one, I'll approach the K-3 II with hopeful but reasonable expectations. Nailing focus at any aperture in any light is a pet project for me in particular, so if I have a wide enough variety of lenses and environments to test in, I hope to be able to very quantifiably determine just how close they are in performance. We'll see how it goes...
06-24-2015, 02:43 AM   #930
Zygonyx's Avatar
Tried K-3ii on DFA150-450 yesterday : no difference in AF speed or acuracy / K-3 in AF-s.
Didn't have opportunity to compare in AF-c.
af, af-c, camera, canon, d-fa, diglloyd, f2.8, features, ff, flash, gps, hardware, ii, iso, k-3, module, nikon, pentax, pentax k-3 ii, pentax news, pentax rumors, price, sample shots, sensor, shot, technology, time, utility
Pentax K-S2 Officially Announced Adam Pentax K-S1 & K-S2 12 05-23-2015 06:49 AM
Pentax K-3 Officially Announced (See our detailed preview here!) Adam Pentax News and Rumors 213 11-18-2014 01:46 AM
Pentax K-500, K-50, and Q7 cameras officially announced! Adam Pentax News and Rumors 346 07-08-2013 01:10 PM
Pentax K-5 II and K-5 IIs OFFICIALLY Announced Adam Pentax K-5 & K-5 II 9 09-11-2012 08:43 AM
Pentax K-5 Officially Announced Adam Pentax News and Rumors 533 03-06-2012 05:45 AM
All times are GMT -7. The time now is 08:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
