Originally posted by mee Pentax support seems to be really really terrible these days..
Unfortunately Roger Cicala hasn't done one of these for a while, and hasn't included Pentax, but it's the sort of survey one needs to do to give 'terrible' or 'great' some real meaning. [See the bottom of the article].
LensRentals.com - Lensrentals Repair Data: 2012-2013
'Terrible' can also be:
(a) a relative measure (relative to the repair turnaround of other companies: a number like 15 days repair turnaround may appear terrible for Pentax, but if Nikon is 25 days, is Pentax still going to be 'terrible'?), or
(b) a quality measure - ie did the repair actually totally fix the problem, or did the problem recur and so the repair needed to be re-done.
Related to quality, there's the time dimension of 'terrible' too.
If a repair is turned around quickly, so the repair shop did the job quickly (and thus you were able to get the camera back in time to shoot that important wedding), you might judge the repair service 'great', not terrible.
But if, 9 months later, the item needs to be repaired again for the same problem, judged over the course of a year, you might indeed judge the repair service 'terrible', since the item had to be fixed twice. But then if the repaired item worked fine for 10 years afterwards, you might re-think whether the repair service was indeed 'terrible' after all.
tl; dr - 'terrible' service and support needs qualification sometimes.
