01-26-2016, 11:40 AM - 1 Like   #346
QuoteOriginally posted by northcoastgreg Quote
You can't necessarily go by what you see on the roadmaps, in terms of focal length. Just look at how the DA 20-40 and the DA 150-450 were represented. No way anyone could have guessed the true focal ranges of these zooms from the roadmap.
Given some of the new rumors suggesting that the Pentax FF may retail for as low as $2,000, Pentax probably has to come out with a standard lens in the $500 range, just for those who can barely afford FF but need a standard zoom to go with it, and that's bound to be a "slow" variable aperture lens. After all, it's hard to image, realistically, a high quality DFA 24-105 f4 for much less than $1,000. If you need a fast standard zoom there's always the DFA 24-70 f2.8.
Canon 24-105 F4 is $1000 at bhphoto at this moment but you can find a lot of places sell it around $500-$600... It is usually sold as a kit lens with 5diii or 6d.
I cannot imagine for people who buy $3000 camera , demand $100 24-105 F3.5-5.6, as a much cheaper APS-C camera with any decent lens eg K50+16-50f2.8 is much better than it...
01-26-2016, 01:04 PM   #347
thibs's Avatar
QuoteOriginally posted by cxdoo Quote
Actually they do. APS-C lens can be made smaller and take the benefit of not needing to cover full FF circle. Also cheaper.
Given the limited production capacity and the focus on FF now, it's reasonable to say that's happening on expense of APS-C.
This is only true for WA to normal FL.
01-26-2016, 01:14 PM   #348
QuoteOriginally posted by Imp Quote
Like this small? Sorry, couldn't help myself
nice one, should develop into a bigger wee leek by the end of Feb.
01-26-2016, 01:36 PM   #349
bilybianca's Avatar
QuoteOriginally posted by cali92rs Quote
Plenty of folks use FF lenses on their D7200 (and will on the D500) as well as on the 7D mkII.
I'm not so plenty, I'm just one, but I use FF lenses on my Pentax K5. Just counted, I have 15 lenses I do use at least occasionally (I'm not a lens collector) and two of them are APS-C DA lenses, the rest are Pentax FF. K, A, F and FA. All work fine on APS-C, nevertheless I'm looking forwards to using them on a digital Pentax FF body. And then I can also start using the two lenses I don't use on APS-C, the A 15mm and K 28mm Shift.
Kjell
01-26-2016, 02:14 PM   #350
Zygonyx's Avatar
QuoteOriginally posted by bilybianca Quote
I'm not so plenty, And then I can also start using the two lenses I don't use on APS-C, the A 15mm and K 28mm Shift.
Kjell
Yes, good find and very suitable for 35mm
01-26-2016, 02:23 PM   #351
Imp
Imp's Avatar
Personally I prefer some FF oriented zoom focal lengths better on aps-c. E.G. I would prefer to have a 24-70 2.8 on aps-c than a 16-50 2.8 - I just like it a bit longer. What I don't like is the resulting size and weight increase because the lens is designed for fullframe... and the cost therefore i'm going to stay with my aps-c zooms
01-26-2016, 05:17 PM   #352
Sounds you are a born APS-C user :-). Fuji in last several years did a wonderful jobs in APS-C world as it delivered a lot of high quality APS-C lenses, I mean, APS-C mount and Fast aps-c lenses... Fuji is a very ambitious company as it is rumored to deliver compact mirrorless medium format camera soon...
Anyway, I think in last several years Ricoh/Pentax had shifted a lot of efforts to 645Z and AF part, instead of developing new lenses. A lot of new patents recently released are focused on AF. K1 will be a AF monster! Let's wait and see!
01-26-2016, 05:53 PM   #353
Imp
Imp's Avatar
QuoteOriginally posted by starjedi Quote
well yes, I am but i'm curious what makes you think so? Because I prefer longer focal lengths? I would like to think i'd prefer longer lenses on FF, like a 35-105 rather than a 24-70...
01-26-2016, 06:36 PM - 1 Like   #354
I am too. It is not easy to use wide angle as it needs more careful composition in many situations. I like FA 31mm on APS-C...
01-26-2016, 08:02 PM   #355
Imp
Imp's Avatar
huh, i've never thought of it that way!
01-27-2016, 12:10 AM   #356
Zygonyx's Avatar
neither did i.
To the contrary, i think wide angle do help in composition, because it gives you better perspectives and thus allows more original framings.
01-27-2016, 12:29 AM   #357
Deimos's Avatar
I think they should bring back the idea of the 50mm prime as kit lens. Revise the DA 50 1.8 or even the DFA* 55 1.4 and make it the new kit-lens for the K-1...maybe I am crazy
01-27-2016, 01:24 AM   #358
iudex's Avatar
QuoteOriginally posted by Deimos Quote
You are not, actually it makes sense to pair FF with standard, i.e. 50mm prime. DA 50/1,8 is APCS (though rumoured to cover FF), but FA 50mm is still relatively cheap and would pair nicely with the K-1.
However it is usual to pair a camera with a zoom kit lens for convenience and since the 24-70 is very expensive (and limited focal range), a cheaper zoom with bigger FR is inevitable. Although in this price league (2000+ USD) there is no need to make the cheapest slow f3,5-5,6 zooms and I hope Ricoh makes something better (constant f4 or at least f3,5-4,5 like the Nikon FF kit zoom).
01-27-2016, 01:32 AM   #359
thibs's Avatar
QuoteOriginally posted by iudex Quote
Completely agree about the standard zoom and the 50mm prime.
AFAICT, the DA50/1.8 is nothing but an FA (or F or A or M, all the same but maybe a tweak here or there) in cheap clothing with round aperture blades.
Same with DA35/2.4, just an FA35/2 but reworked.
A modern 50/1.4 would be very appropriate, yes in kit too.
I'd opt for the zoom as I already have a couple 50's though and I doubt the olf 28-80/3.5-4.7 powerzoom would shine on an FF modern cam.
01-27-2016, 06:47 AM   #360
All the FF brands have at least one cheap kit zoom available:
- Nikkor 24-85mm f/3.5-4.5G ED VR Lens
- Canon EF 24-105mm f/3.5-5.6 IS STM
- Sony FE 28-70mm F3.5-5.6 OSS
Pentax will probably make one available too, I bet. Having one on offer makes sense.
25th 2016 cp, alive, camera, countdown, countdown to feb, coverage, cp, days, features, feb 25th, ff, flash, imo, matter, music, pentax, pentax news, pentax rumors, people, post, screen, shift, smartphone, thread, time, upload, vf, youtube
New APSC Pentax by early 2016, using Sony A7000 sensor? falconeye Pentax News and Rumors 857 03-24-2016 08:45 PM
Ricoh Imaging is not doomed (or: Ricoh Financial Results Q1 2016) Kunzite Pentax News and Rumors 69 10-24-2015 10:31 AM
Pentax FF spring 2016 Daikokuya Pentax News and Rumors 971 10-14-2015 06:31 PM
2016 spring debut hansenn Pentax Full Frame 12 09-25-2015 08:05 AM
Photokina 2016 - FF RonHendriks1966 Pentax Full Frame 62 02-04-2015 10:43 PM
All times are GMT -7. The time now is 12:03 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
