02-16-2016, 12:50 PM   #1426
Mistral75's Avatar
The technical solution is just a supposition; same effect can be achieved by redesigned optics. Perhaps to an even greater extent than the second image.
I am afraid it can't otherwise other manufacturers would have done it and Ricoh Imaging themselves for the Pentax 645D and 645Z.
02-16-2016, 12:57 PM   #1427
QuoteOriginally posted by screwdriver222 Quote
Zoom function in OVF
For precise manual focus :-)
02-16-2016, 01:09 PM   #1428
QuoteOriginally posted by Mistral75 Quote
Other manufacturers have better coverage without concave mirrors (on some of their cameras), and Ricoh Imaging haven't redesigned the AF for the medium format cameras in order to save cost.
02-16-2016, 01:16 PM   #1429
Are you certain?
K-1: AF points coverage with standard secondary mirror.
So small coverage at all??
02-16-2016, 01:20 PM   #1430
Mistral75's Avatar
Indeed but the coverage of one particular AF module (in absolute terms) only depends on the module itself and doesn't change between the various sensor formats with which it's used: for instance, it's always 1.5 more centred on Nikon's 24x36 bodies than on their APSC bodies (e.g. D3/D500 or D5/D500).
Since K-1 and K-3/K-3 II share the same piece of hardware...
...there is necessarily some trick somewhere.
---------- Post added 02-16-2016 at 09:21 PM ----------
QuoteOriginally posted by starjedi Quote
Without any 'trick', I'm afraid so.
02-16-2016, 01:25 PM   #1431
How could they, if they have different focus point counts?
02-16-2016, 01:28 PM   #1432
Optics
02-16-2016, 01:39 PM   #1433
There is a lens array and mask in front of the K-3 AF sensor that guides it's coverage:
I am very curious to see how the K-1 AF assembly looks.
02-16-2016, 01:41 PM   #1434
redpit's Avatar
Relax and enjoy the last few hours before the FF revealing! Nothing will be the same from then on!
As for the hidden aces in this K-1 if it was easy to predict then it wouldn't be a Pentax unique camera! We will find out soon what's the Pentax way of building a FF. It's obvious it won't be just another "me too" product in the market and it will have character. That is what I love to Pentax!
02-16-2016, 02:00 PM   #1435
Mistral75's Avatar
QuoteOriginally posted by jaad75 Quote
Because the K-3/ K-3 II's autofocus is somewhat crippled.
What follows is based on the recent rediscovery of an older post by bwDraco/DragonLord:
https://www.pentaxforums.com/forums/172-pentax-k-3/297512-how-much-better-af-...ml#post3287934
In the viewfinder of a K-3 or K-3 II there is a significant gap between either side point and the main AF area.
There are seven columns of selectable AF points in the viewfinder but nine columns of physical sensors in the AF module.
(note that the five inner lines of physical sensors in the AF module correspond to the five lines of cross-type sensors and the three outer lines, with their enlarged telemetric base, correspond to the three f/2.8 sensors)
The two extra columns, which appear to be unused on K-3 / K-3 II, would be enabled on K-1, each for three AF points, thus giving a total of 27 + 3 + 3 = 33 AF points, of which 25 correspond to cross-type sensors, as indicated by Digital Camera Info.
Judging by the spacing of the two brackets inscribed on the focusing screen of K-1, as seen by reflection on the mirror and which most likely correspond to the outer AF points (as with other Pentax cameras), it seems that Ricoh Imaging has found a way to enlarge the AF point coverage
compared to what the K-3 / K-3 II module would spontaneously produce on K-1.
Finally, remember that Ricoh Imaging have been granted a patent for a concave secondary mirror to enlarge the coverage of the AF module:
Ricoh ?????????AF?????????????????So-net???
Et voilą!
02-16-2016, 02:00 PM   #1436
Shanti's Avatar
Jaw drop #3..silent/electronic shutter..
02-16-2016, 02:06 PM   #1437
Mistral75's Avatar
Less than 25 hours till Christmas K-1's announcement.
02-16-2016, 02:11 PM   #1438
What If that's what the mysterious extra scroll wheel does on the top of the right side? Zooms in and out?
02-16-2016, 02:12 PM - 1 Like   #1439
Zygonyx's Avatar
That is a question wheel
02-16-2016, 02:14 PM   #1440
QuoteOriginally posted by disasterfilm Quote
Or... dioptric adjustment.
25th 2016 cp, alive, camera, countdown, countdown to feb, coverage, cp, days, features, feb 25th, ff, flash, imo, matter, music, pentax, pentax news, pentax rumors, people, post, screen, shift, smartphone, thread, time, upload, vf, youtube
New APSC Pentax by early 2016, using Sony A7000 sensor? falconeye Pentax News and Rumors 857 03-24-2016 08:45 PM
Ricoh Imaging is not doomed (or: Ricoh Financial Results Q1 2016) Kunzite Pentax News and Rumors 69 10-24-2015 10:31 AM
Pentax FF spring 2016 Daikokuya Pentax News and Rumors 967 10-14-2015 06:31 PM
2016 spring debut hansenn Pentax Full Frame 12 09-25-2015 08:05 AM
Photokina 2016 - FF RonHendriks1966 Pentax Full Frame 62 02-04-2015 10:43 PM
All times are GMT -7. The time now is 11:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
