Originally posted by ogl Hurka Thing screen Natural-Bright-Matte III - what is it?
I corrected the translation. The first one was automatic, the current one is mine. Here below the corrected one
- 36.4MPix CMOS sensor without low-pass filter
- Pixel Shift Resolution
- PRIME IV image processing engine
- Sensor size: 35.9 x 24.0mm
- Full HD 60p video
- 4K time-lapse movie
- 14-bit RAW
- DR II
- KAF2 mount (compatible with KAF3, KAF2, KAF, KA and power zoom lenses)
- SAFOX12 AF sensor. 33 AF points of which 22 are cross-type. -3EV sensitivity
- AF assist light
- Viewfinder magnification: 0.70x. 100% field of view
- Natural-Bright-Matte III focusing screen
- 3.2 inches, 1,037,000 dot LCD monitor. Flexible tilting
- Built-in GPS and Wi-Fi
- Shutter unit of compact new design. MTBF: 300,000 cycles
- Shutter speed: 30 seconds -1/8,000s. Synchro speed: 1/200 sec
- Media: SD / SDHC / SDXC (UHS-I). Dual card slot
- USB connector (USB 2.0), HDMI connector, microphone jack, headphone jack, X contact
- 5-axis camera shake correction. 5 f-stops efficiency
- Electronic level
- Photometry sensor: 86,000 pixel RGB sensor
- ISO range: 100-204,800
- Continuous shooting: 4.4 fps (24x36) / 6.5 fps (APS-C)
- Buffer capacity: 70 JPEG shots, 17 RAW shots (24x36, 4.4 fps)
- D-LI90 battery
- Battery life: 760 pictures
- Body: magnesium alloy and stainless steel. Dust and water resistant. Resistance to low temperature: -10 °C
- Size: 136.5 x 110 x 85.5mm
- Weight: 925g
