02-15-2016, 06:59 PM - 2 Likes   #166
Here's my best example of a fast burst:
02-15-2016, 07:54 PM   #167
CRPhoto's Avatar
That's an improvement from K-3's 560 frames; using the same battery.
The fps is decreased, but there's more data to be processed per frame.
Those number are weird. I've gotten over 800 shots on the K-3 with one battery (and without running it empty). No flash, daytime, jpgs. No problems or complains with the K-3 battery life, and don't see why the K-1 would be any different (well actually it should have much better battery life).
02-15-2016, 07:55 PM   #168
QuoteOriginally posted by rlatjsrud Quote
Duh, that's not even convenient for long exposure.
Okay.
02-15-2016, 08:06 PM   #169
WPRESTO's Avatar
QuoteOriginally posted by reh321 Quote
What do you photograph that changes more than four times per second?? I sometimes photograph trains going 50 mph, and I find that my K-30 set at the lower burst rate (3 fps) is more than enough to get the picture I want (assuming I remember to set it to burst at all).
The shot below was taken at the K3's highest frame rate. Focus and exposure preset to capture the male or female bluebird in flight as they brought food to youngsters in a nest box Observed them for a while so I knew approximately where to frame, but I kept the camera back to include much more area than required to capture the bird (image below cropped to less 1/3 or so of the original). Even at 1/3200 second the wings are blurred, and even at the highest frame rate the bird would be wholly recorded in flight in no more than two frames of the burst. The image below was posted in 2014 in a different thread, Apologies to anyone who's already seen it.
02-15-2016, 08:14 PM   #170
Agreed. My GR is limited to 30sec. In all modes but M. In M mode it allows for a slow speed of 300 seconds followed by B (bulb) and T (time). Maybe the M setting on the K1 will have a similar implementation. Exposures longer than 30sec without having to touch the camera would be nice.
---------- Post added 02-15-2016 at 10:18 PM ----------
Why not? You use a remote that costs maybe $20, set the delay, the time of exposure and push the button. What am I missing?
Possibly the fact that there are much more elegant and intuitive solutions. See the GR implementation as an example. I'm curious; how do Canon and Nikon handle this?
02-15-2016, 08:21 PM   #171
rlatjsrud
Guest
Max long expose is 30sec. You can't expose longer than 30 sec.
02-15-2016, 08:24 PM - 2 Likes   #172
Digitalis's Avatar
yes you can, in Bulb mode. The time you can leave the shutter open is pretty much limited by the battery life of the camera.
Pentax K5IIs - SMCP-FA31mm f/1.8 ASPH Limited ISO80 f/11 1m30s + Lee Big stopper ND filter used.
02-15-2016, 08:26 PM   #173
QuoteOriginally posted by CRPhoto Quote
CIPA standard measuring for battery life includes lots of in-built flash usage, if fitted. If you shoot your K-3 outside of test conditions (eg no flash, minimal rear LCD usage, no video usage, RAW only, SR turned off, no usage of SDM etc) your shot count will increase.
Since the K-1 has no flash, that fact by itself may help bump up the baseline battery life/image count stats relative to K-3.
02-15-2016, 08:27 PM   #174
Emperor and Senpai
VoiceOfReason's Avatar
You also get longer than 30 seconds using Astrotracer.
02-15-2016, 08:32 PM   #175
That people don't want to have to carry around yet another accessory in the dark?
I have a hard time imagining that a programmable bulb mode would be very complicated when, as you say, a $20 remote can do it. But it would be very appreciated by those who'd use it.
02-15-2016, 08:38 PM   #176
rlatjsrud
Guest
Does it even have a scale more than 30 sec? Bulb mode? No. I want the exact exposure and I don't rely on guessing exposure at all.
02-15-2016, 08:45 PM   #177
Digitalis's Avatar
You can mentally calculate the exposure*, or of that is too mentally taxing for you to manage: use a handheld exposure meter.
QuoteOriginally posted by indy Quote
the same way as Pentax does. With Bulb mode.
QuoteOriginally posted by VoiceOfReason Quote
you also get longer than 30 seconds using Astrotracer.
The problem with that is the sensor is moving when you use the astro tracker.
* if your metered exposure is 1s at f/8 ISO 100, then how much longer would the shutter have to be open if you put a ND10 filter on your lens?
02-15-2016, 09:25 PM - 2 Likes   #178
Pentax could add 45, 60, 90, 120, 180 second shutter speeds to M mode. The hardware can already keep the shutter open that long so it's probably a simple firmware change.
02-15-2016, 09:31 PM   #179
jatrax's Avatar
I don't have a GR.
Well, no it is not. You just use bulb mode and set what time you want.
QuoteOriginally posted by BrianR Quote
Ok, that is a valid complaint. But outside of that I guess I'm not missing anything.
02-15-2016, 09:33 PM   #180
QuoteOriginally posted by Wired Quote
The big thing I would absolutely love is if the camera will allow the hot shoe to be triggered at any shutter speed regardless if it's within the sync speed or not.
Looks like you do not understand how it works. It may be a good idea to read up on this.
Basically allowing this will give you unusable images exposed half way 3/4 way or vignetted due to the shutter. A higher sync speed requires your flash duration to be longer than the sync speed (specialised equipment).
1/180 gives you the liberty to use all the generic strobes out there on the market which is low cost of ownership and is desirable.
No offense meant.
af, anyway, battery, battery life, buffer, built-in, camera, estimate, exposure, frames, gr, jpeg, k-1, length, menu, mode, pentax news, pentax rumors, phone, price, sec, sensor, sheets, shots, shutter, size, specs, speeds
is there a full DA list?? FA out of production? Albert Siegel Pentax SLR Lens Discussion 9 04-21-2019 12:06 PM
K-1 likely in full production run now... Fenwoodian Pentax Full Frame 24 12-11-2015 11:20 AM
Pentax Full-Frame to be Named K-1 PF Staff Homepage & Official Pentax News 16 11-17-2015 10:13 PM
Adorama Pentax Lens Deals - Full List 12/1 Adam Pentax Price Watch 3 12-03-2012 12:49 PM
News Full List of Forum Features Adam Site Suggestions and Help 6 08-09-2009 10:25 PM
All times are GMT -7. The time now is 07:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
