02-21-2016, 04:17 AM   #31
kenspo's Avatar
QuoteOriginally posted by zapp Quote
Key questions is: Did Pentax already present all lenses they want to introduce with the K1... no 70-200, no primes... let's hope for a full roadmap.
24-70 is out. 15-30 and 70-200 ships with K-1. 150-450 is out. Same with 31, 43, 55, 77, 100, 200 and 300 (all works brilliant with K-1)
More lenses will come, so relax.
02-21-2016, 04:27 AM   #32
The 70-200 was announced a year ago, it's market launch then postponed for modifications. It should be here soon.
02-22-2016, 08:09 AM   #33
lumbangorat_16's Avatar
Better 135 f/1.8 star or limited grade, 20mm, 24mm, 85mm, 200 macro enough
02-23-2016, 04:03 AM   #34
Pål Jensen's Avatar
There won't be a 135/1.8, or any 135mm lens - with the theorethical exception of a macro lens, because no one is buying them.
02-23-2016, 04:34 AM   #35
Sandy Hancock's Avatar
The DFA*70-200 has been officially slated for 18th March release, so there's no urgent need for a 135mm prime if the zoom is as good as expected.
A fast wide prime is a higher priority IMHO. Somewhere in the 20-24 range. A camera pitched at astrophotography needs that, unless the 15-30 is truly exceptional.
02-23-2016, 04:40 AM - 1 Like   #36
Digitalis's Avatar
I have used this lens in a comparative review in F mount on the D810 against the Nikkor 14-24mm f/2.8G and the Nikkor 16-35mm f/4G - the Tamron 15-30mm gave both nikkor lenses a run for its money, especially regarding field curvature and coma control*. On my optics bench: MTF tests showed that the Tamron and the Nikkors both had their strengths and weaknesses, The Tamron lens had the most consistent resolution curve throughout the zoom range** compared the to two Nikkor lenses, both of which had clearly been designed to give the best IQ at the wide/long ends of their zoom ranges.
* Strangely the two f/2.8 lenses had less distortion than the nikkor 16-35mm f/4
**The nikkor 14-24mm f/2.8G was hot on its heels, beating it slightly at the 17~20mm range.
02-23-2016, 04:46 AM   #37
That is very encouraging. What did you make of its flare resistance?
02-23-2016, 04:55 AM   #38
Digitalis's Avatar
Compared to the DA15 they all sucked.
In all seriousness, the Nikkors with their highly advanced nano crystal coat AR technologies held a distinct advantage over the Tamron lens. I'll admit my flare testing wasn't thorough: there are about 16 types of flare a lens can suffer from, and setting up the lighting that typically provokes them can be difficult, so I just covered the basics. Hopefully Pentax will seek to remedy this by employing their own coating technologies, that would provide a welcome boost to the IQ from the Tamron 15-30mm f/2.8. But all things considered I have seen worse flare tolerance from lenses in this focal length range, compared to the aforementioned lenses I tested: the sigma 12-24mm is a disaster.
02-23-2016, 01:47 PM   #39
As I feared. Despite my desire to rationalise I don't think I'll be able to bring myself to move on my DA15 and DA21.
02-23-2016, 02:13 PM   #40
QuoteOriginally posted by kenspo Quote
Even Pentax tells you that the 55 needs to be stopped down on K1. Pentax desperately advertised the K1 with FA* 24 and 85 - found on eBay. 31, 43, 77 are decent lenses even today, but not convincing for a FF camera. Pentax used to be known for compact footprint, great quality prime lenses with useful specs - not too large, not too extreme. Big 2.8 zooms and no new/updated primes are a change in policy. More lenses = new road map at the most.
02-23-2016, 02:29 PM - 1 Like   #41
QuoteOriginally posted by lumbangorat_16 Quote
Probably Pentax will launch the 135mm lens with a new version of FF camera for sports and action.
02-23-2016, 02:32 PM   #42
QuoteOriginally posted by Pål Jensen Quote
Better tell Zeiss and Samyang:
Apo Sonnar T* 2/135 | ZEISS United States
Samyang Optics, Lenses for Camera ? Cine ? Photo - VDSLR, Prime Lenses & Third party Lenses
02-23-2016, 03:10 PM   #43
QuoteOriginally posted by Lightograph Quote
"Probably"? Or " I hope"?
02-23-2016, 03:22 PM - 1 Like   #44
Ooh! Shiney! Me Want!
monochrome's Avatar
Given that a K-3 has size, weight and format benefits vs. K-1, keeping K-3 specifically for use with DA Limited lenses seems like a reasonable choice at current resale prices. K-S1 & K-S2 are preference items. That makes 1 - 3 reasons to keep the 15 and 21 n
Rational and photography don't play well together.
02-23-2016, 04:42 PM   #45
I see the K-3 line and K-1 lines working in tandem for a lot of us. K-3 and some of the DA's are a wonderful discrete travelling / photo journalistic setup. I for one would prefer to take the K-3 and a trio of 15, 43 and 77 if I was taking a city break for example over the K-1 and DFA24-70 or DFA28-105 or in prime terms the 31, 55, 100 which would be the nearest equivalent currently available. I have purposely omitted the 21 as it is very much outshone by its wider brother. Some may ask why not just use the K-1 in crop?, if you have a 24Mp why lock yourself to 15Mp? would be my retort.
If doing some landscapes or available light gig work then K-1 I'm very hopeful will be the no need to question option. I have a 25mm Zeiss for the landscapes and 43, 50 f/1.2 and 77 for the gig work with the 50 @f/2.0 probably edging it in my minds eye right now. Should be fun working through these conundrums in the near future.
15-30mm, aperture, design, fa, lens, lenses, pentax, pentax news, pentax rumors, range, ratio, sense, slash
D FA lens with full performance on new K1? Uncle Pete Pentax Full Frame 15 12-17-2015 05:25 AM
Why the new lens PENTAX D FA 24-70mm F2.8 is green and no red line? Arturopentax Pentax SLR Lens Discussion 21 09-28-2015 06:33 AM
FA Limiteds vs. the new D-FA 24-70 zoom 6BQ5 Pentax SLR Lens Discussion 31 09-27-2015 11:38 AM
Wanted - Acquired: Pentax 100mm 2.8 macro, F, FA, D-FA, D-FA wr rwingsfan Sold Items 2 04-28-2014 01:23 PM
Short comparaison 100mm Macro D-FA vs NEW D-FA WR fourmiX Pentax SLR Lens Discussion 36 03-12-2010 09:48 PM
All times are GMT -7. The time now is 12:45 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
