Originally posted by fromunderthebridge First, to address my thoughts on the PS discussion (not directly directed to Rondec). I do agree wrt. the commentary on the sensor readout speed, disagree on some people's proclivity to judge before seeing actual results (some people should eat their 'vitamins') and finally hope for the best.
Sorry, I'm replying on a bit of a tangent here on the tripod use, however, tripod isn't always that simple. I have to say that in some cases the tripod has to be an absolute monumental, hulking and heavy beast (try high arctic winds
) to be of any use. Unfortunately on some of these same situations dragging such a tripod with is highly impractical. As such, potential for hand held shots is actually appreciated. Not disagreeing per se, just pointing out fringe use cases.
I am not sure how often you would actually get better results hand held than with a tripod. If you have an arctic wind blowing, odds are that you will be more stable on a tripod than hand held, although to be sure, you probably should bump your iso somewhat as well.
I just have an issue with people universally dismissing PS as a "I'll try it a couple of times and never use it again," feature, when the results I have seen are pretty impressive.
