Originally posted by wizofoz I wonder if you would be so kind as to inform them that the same issue exists for the 58 AF-1
Thanks
I think Metz-Pentax is aware of the problem with the 58 AF1 as well - it's almost identical with the AF-2 one.
The weak thing with the AF-1 was that the plastic shoe often broke - the AF-2 shoe is of metal and much stronger.
I have heard that if you are very handy you can change the AF-1 shoe to an AF-2 shoe.
By the way - doing all tricks mentioned above I have a problem.
For example using A-setting on the Metz.
When regulating exposure with the +/- button on the camera - nothing happens - I alway get a theoretical correct exposure. That is " -3 " gives the same exposure as the " 0 " setting with the flash on.
Perhaps I'm doing something wrong - something else to be set?
