Show Printable Version 27 Likes Search this Thread
06-03-2016, 05:09 AM   #76
From what I've seen, a K-1 wide open at ƒ4 and 6400 ISO, would have less noise than a K-3II at ƒ2.8 and 1600 ISO, the same DoF, half the weight. of a comparable 2.8 lens, Having a 60-250ƒ4 instead of a 70-200 ƒ2,8, I have to say, this would be a lens I might be interested in if the cost differential, is like that of the 60-250 and the 70-200, and the quality is up there with the 60-250, I have an FA 35-80 I use occasionally on APS-c. It would be a lot more useful on FF,
Sounds like you're slowly getting contaminated by the K1 virius :-)
06-03-2016, 05:22 AM   #77
normhead's Avatar
As always, I look at the images and read the technical stuff. Others look at the K-1 as an advancement to their photographic hopes and dreams. I look at it more as a more affordable manageable replacement of my desired 645z.
I've never felt there was no benefit to a FUll Frame, just for me, APS-c makes more sense. If i get a K-1 it will be largely a closet camera. Useful for when I'm not walking with the system, or someplace where landscape is possible but wild life isn't. As long a I have a K-3 and a back up for my K-3 adding a K-1 will be a possibility. But it will never be my "bread and butter" body.
I can see the advantages, but, 100-800 ISO where 99% of my shooting is done, a K-1 has little to offer. You can see the difference in the Imaging resources cloth images, But I don't think those kinds of differences lead to a photograph being better very often. I still think 36 MP images are overkill. APS-c is still the best set of compromises for me.
RIght now a K-3II with pixel shift is a lot more attractive.
But if at some point I have chance to add a few K-1 abilities to my APS-c based system for use when appropriate, I might do that.
06-03-2016, 05:33 AM   #78
Mistral75's Avatar
QuoteOriginally posted by D1N0 Quote
If the patent said 24-105 I would believe it, the dimensions and number of elements would make sense. Nikon Canon and Sigma Have Similar offers. All struggle at being excellent though.
Do not rely on websites such as egami as far as focal length and other specifications are concerned. They take them out of one of the several examples in the patent.
For instance the patent recently presented on the Internet as pertaining to a 100-300mm f/4 shows the optical formula of the D FA★ 70-200mm f/2.8: egami just chose the wrong embodiment.
06-03-2016, 05:51 AM   #79
gazonk's Avatar
QuoteOriginally posted by Mistral75 Quote
Aha, thank you, that's interesting.
The complexitiy of the construction looks closer to that of some wide range zooms (like Nikkor 24-120 or Canon 24-105), which would make a lot more sense.
06-03-2016, 06:04 AM   #80
D1N0's Avatar
so where would I find the original patent?
06-03-2016, 06:24 AM   #81
Mistral75's Avatar
Here: https://www.j-platpat.inpit.go.jp/web/all/top/BTmTopPage
06-03-2016, 06:41 AM   #82
D1N0's Avatar
tried that but the only thing I find is this https://www19.j-platpat.inpit.go.jp/PA1/cgi-bin/PA1DETAIL?MaxCount=1000&Page...1o1j&Reserve3=
in 2016
06-03-2016, 06:58 AM   #83
Mistral75's Avatar
i don't imagine there will be an English abstract for a patent which was just published. The more recent abstracts correspond to patents published on January 28th.
One has to browse the Japanese section to find it.
06-03-2016, 07:12 AM - 2 Likes   #84
D1N0's Avatar
I'll go study Japanese for three years first then
06-03-2016, 08:23 AM - 1 Like   #85
normhead's Avatar
If your language skills are like mine, that might not be enough.
06-03-2016, 09:04 AM   #86
i now have both K3 and K1, and yes, K1 isn't the camera to bring about anywhere. First it's more expensive (so if you break it , or it get stolen, it's more a problem than if it was a cheap camera), second the image quality of the K1 isn't far from the K3's... (since I have experienced the K1, I love the K3 more...), third together with the lenses it's becomes large and heavy (I can take the K3 with a couple of primes in a small backpack on a bike, but I don't think I'll ever do that with the K1). With the K1, the latitude of the sensor still no solved... because it's a property of the digital sensors vs film, regardless of the sensor size, so in fact, the final image rendering depends much more on digital post processing skills rather than sensor size.
06-03-2016, 09:17 AM   #87
QuoteOriginally posted by Sliver-Surfer Quote
resolution
less noise
sharpness
narrower chromatic aberration
more compressed images(less Perspective distortion)
Resolution - I agree
Less noise - Disagree, using f/2,8 on APS-C yelds as low noise as f/4 on FF, given the same shutter speed, scene and so on.
Sharpness - You already mentioned that
Narrower CA - I'm not sure that holds true as a general property.
More compressed images - That does not hold true. Telephoto compression is a function of field of view. Given that you choose lenses with the same FoV, the compression will be the same.
Edit: Try googles translation of the patent. It will save you years of study to get to that quality level of Japanese.
06-03-2016, 12:25 PM   #88
QuoteOriginally posted by Simen1 Quote
Good Grief! Are you serious?
06-03-2016, 12:42 PM   #89
bilybianca's Avatar
QuoteOriginally posted by johnmflores Quote
What benefits would the K-1 with a bag of F4 zooms have (if any) over a K-3 II with a bag of F2.8 zooms?
Maybe not a bag full, but to me with a number of fast HQ prime lenses it would be nice to have a lightweight walkaround lens, like I have used my DA16-45 on APS-c. With the K-1 high ISO capacity f4 would be plenty good enough.
Kjell
06-03-2016, 01:18 PM   #90
@Silver-Surfer: I'm just happy to help. If you still wonder about something, just ask.
f/4, f/4 full frame, files a patent, frame, patent, pentax, pentax 35-80mm f/4, pentax news, pentax rumors, ricoh, ricoh files
Nikon files patent for mirrorless full frame lens neostyles Canon, Nikon, Sony, and Other Camera Brands 2 12-18-2014 07:21 PM
Nikon Patent for Full Frame Mirrorless Lens Winder Canon, Nikon, Sony, and Other Camera Brands 3 12-16-2014 06:49 PM
ricoh files patent on 2 Q lens designs and on 4/3 design! shaolen Pentax News and Rumors 20 08-21-2014 12:03 AM
Tamron patent for a 15-50mm f/1.4 lens? Phil A Pentax Q 2 04-17-2014 08:07 PM
Pentax files a patent for a DA*25-350mm F3.3-5.6ED [IF] SDM lens grandnax Pentax News and Rumors 50 01-25-2011 08:57 AM
All times are GMT -7. The time now is 06:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
