06-20-2016, 12:45 AM   #121
"f you [...] have equivalent apertures", and you should add "equivalent" ISO and the same shutter speed - this is exactly the idea that I'm challenging. You don't have to. I don't believe in a single exposure setting which would always be correct for a given photo.
06-20-2016, 01:03 AM   #122
Equivalency is a prerequisite for comparability. You don't have to compare. But if you do, you should have equal expressions on each side of the equation.
06-20-2016, 04:00 AM   #123
And once again, I disagree. That theory might be, or might not be a prerequisite - it all depends on what you're comparing.
Yet if you ask its advocates, they won't say anything other than repeating the conditions required by that theory. Are they even comparing something, or just supporting that theory?
You shouldn't assume that you can have "equal expressions on each side of the equation". You can't. You're talking about different formats, and - obviously - different cameras; they're not the same.
06-20-2016, 04:07 AM - 1 Like   #124
You are correct. 30mm f2 and iso 100 and 1/200 second on APS-C should be roughly equivalent to 45mm iso 200 and 1/200 second on full frame. People do tend to leave the iso out of the equation for some reason, but if you don't change it, then you won't get a correctly exposed image on one format or the other.
I guess I am more irritated by the whole "full frame doesn't have perspective distortion because it uses proper focal lengths, but APS-C does." If you use equivalent focal lengths and have similar framing, you really can't tell the difference (except that certain lenses do render differently).
06-20-2016, 04:24 AM   #125
I would be irritated by that idea, too. Perspective depends on your station point (in relation to the subject), right? We don't need needlessly complicated theories for that, just understanding of the basic concepts.
06-20-2016, 04:42 AM - 1 Like   #126
Fogel70's Avatar
Yes, equivalence is good for this too.
Capturing a images from the same spot pointed at the same spot with lenses using same FOV will capture equivalent frame regardless of sensor size. And if using same size on aperture, equivalent DOF will be captured. If also using the same shutter speed they will both capture equivalent noise levels if both images is captured with sensors of equivalent sensor tech.
06-20-2016, 05:35 AM   #127
Pointless discussion, as usual. Why on Earth would I have to think about exposure and DOF when discussing perspective? Why on Earth should I think about imaginary "equivalent sensor tech" when perspective doesn't care about sensor technology at all?
I'm out. I can't change your way of thinking, anyway.
06-20-2016, 05:46 AM   #128
Maybe. But it is trotted out multiple times that a 55m on APS-C sucks for portraiture while an 85mm is awesome on full frame. The reality is (assuming the same quality lens) that you'll have a hard time telling them apart.
As to the rest of equivalence, I still find it pretty useless. The widest apertures on full frame lenses (the ones that prove that full frame is better) are pretty useless to me due to lack of depth of field. I like it. It has nice resolution and particularly with pixel shift, you can get pretty awesome images with amazing dynamic range. But a K3 is pretty sweet camera too and more than capable.
06-20-2016, 08:24 AM   #129
Fogel70's Avatar
But the fun thing is that you know this because you are fully aware of the equivalence between these two formats, and are aware of difference in equivalence on available equipment on both formats.
Equivalence is just something that every experienced photographer is so used thinking about that they are not aware of using it.
06-20-2016, 09:17 AM   #130
QuoteOriginally posted by Simen1 Quote
With comparatively low market share it doesn't make sense to have very many overlapping lenses. I don't see the need for the f/4 zoom line that Na Horuk mention unless it offers some other unique features.
While I doubt we'll see an f4 trio, that doesn't mean there isn't a need for alternatives to the existing f2.8 trio. We need a wide angle zoom with filter rings that costs significantly less than $1,500. And we probably need a lighter, less expensive alternative to the 70-200. What would make the most sense for Pentax, and probably could be done fairly easily, is introduce a DFA 18-35 f4-5.6 and a 70-300 f4-5.6. If those lenses featured comparable quality to the DFA 28-105, you could have a very solid variable aperture trio that was reasonably priced, much less heavy than the f2.8 zooms, and just as good, optically, as an f4 trio would likely be.
06-20-2016, 10:31 AM   #131
Well let us wait till infos come out for this lens.
06-20-2016, 11:32 AM   #132
About that perspective thing...there might be a point, But. I was shooting with my Samyang 14 on my K-3 and my Tokina at-x pro on my K-1. If I zoom tokina around 22 mm to get similar Fov I can relly already W/o PP see that lines are more straight with tokina, just because distortion is not as big as on wider lense. It looks about the same, but is not and if you have really well corrected lens for 20 mm, it will look more 'natural' tan lens with similar FoV on APS-C.
sometimes these things matter more, some times not at all.
06-20-2016, 12:30 PM   #133
starbase218's Avatar
Location: Planet Earth, Sol system, Milky Way galaxy, Universe
Is it possible they just patented this in case they ever want to build it, but without any immediate plans for doing so? I know some companies work like that; they patent everything that can be patented, to be on the safe side.
I mean, they also patented a stabilized AF sensor I think. That was something like 5 years ago. So far, they haven't implemented that either.
06-20-2016, 04:45 PM   #134
Transit's Avatar
You young whippersnappers with all your lens choices
We were lucky if a 28 joined the 50...and a 135 ? luxury
06-20-2016, 05:24 PM   #135
monochrome's Avatar
Because I am an old guy I think in FF and translate on-the-fly to APSc. I never learned to think in APSc. For my K-3, which is now a light travel kit, I bought several second-hand DA primes (15, 21, 35, 70) from sellers preparing for K-1. On K-1 my existing FF lenses no longer require backward translation.
Either way, I just compose and expose to what I have with me, but it is more natural for me with my FF lenses on K-1.
f/4, f/4 full frame, files a patent, frame, patent, pentax, pentax 35-80mm f/4, pentax news, pentax rumors, ricoh, ricoh files
Nikon files patent for mirrorless full frame lens neostyles Non-Pentax Cameras: Canon, Nikon, etc. 2 12-18-2014 07:21 PM
Nikon Patent for Full Frame Mirrorless Lens Winder Non-Pentax Cameras: Canon, Nikon, etc. 3 12-16-2014 06:49 PM
ricoh files patent on 2 Q lens designs and on 4/3 design! shaolen Pentax News and Rumors 20 08-21-2014 12:03 AM
Tamron patent for a 15-50mm f/1.4 lens? Phil A Pentax Q 2 04-17-2014 08:07 PM
Pentax files a patent for a DA*25-350mm F3.3-5.6ED [IF] SDM lens grandnax Pentax News and Rumors 50 01-25-2011 08:57 AM
All times are GMT -7. The time now is 12:25 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
