06-08-2016, 02:02 AM   #166
Pentax had said before that the K-S2 was the replacement of the k-50. if that is so, this camera must be much better than the k-S2. Probably some features of the k-3/II will be incorporated in this thing.
I expect that the K-3II's replacement will be even better.
Still, one of my requested feature is better noise handling for high ISO low light shots. Please Pentax, please.
06-08-2016, 02:47 AM - 2 Likes   #167
Mistral75's Avatar
Still from Digital Camera Info, a more complete list of specifications (I have updated the first message in this thread) together with some pictures:
??????K-70?????????? - ????info
Also in so-called silver:
06-08-2016, 02:54 AM   #168
aurele's Avatar
i'm guessing the interesting part is on the back
06-08-2016, 02:56 AM   #169
richandfleur's Avatar
Looks like the high quality SR of the K-3ii
https://translate.googleusercontent.com/translate_c?depth=1&nv=1&rurl=transl...CpQ4MsuSjfBHyQ
No mention of SR during video recording. K-3ii couldn't get this to work, nor the K-1.
Same burst rate and small buffer of the K-30 and max shutter speed etc. Still that same core underneath.
06-08-2016, 03:00 AM   #170
aurele's Avatar
QuoteOriginally posted by richandfleur Quote
it mean the K3ii will get a substancial upgrade i guess
06-08-2016, 03:07 AM   #171
Imp
Imp's Avatar
QuoteOriginally posted by aurele Quote
which, of course, they won't show us yet
Nice blend of the K-s2 and K-50 design - maybe it is replacing both after all
Hey look, its got 14 bit output now! And it now very clearly says "Continuous autofocus in video mode." Whoohoo!
QuoteOriginally posted by Mistral75 Quote
mproved ergonomics of back button and mode dial
Improved compared to... the K-s2? Further support that Pentax is blending the K-50 and K-s2 lineups?
Estimated RRP: JP¥78,000
Approx. 730USD - not bad at all. Respectable.
06-08-2016, 03:16 AM   #172
gazonk's Avatar
QuoteOriginally posted by Imp Quote
Doesnt it look almost exactly like the K-s2?
Great!!
06-08-2016, 03:18 AM   #173
D1N0's Avatar
QuoteOriginally posted by digicame:
Specs of the Pentax K-70
- Enable 24,240,000 pixels. Low pass less. 14bit readable
- The highest sensitivity ISO102400
- Image processing engine PRIME MII
- Adopt a hybrid AF of the image plane phase difference AF and contrast AF to AF during live view
- Dust and water body which has been subjected to 100 places of sealing
- Low temperature minus 10 degrees
- Grip, which is also considered to hold at the time of glove use
- Improve the operability review the shape of the back button and the mode dial
- Equipped with a friendly red screen display function to eyes accustomed to the dark on the monitor
- AF system SAFOX X. AF point is 11 points (central 9 points cross). -3EV Correspondence
- Select area expansion function. AF hold function
- Camera shake correction built. Effect is 4.5 stages. Automatic detection panning
- Realistic resolution system. Motion correction function
- Low-pass selector function
- GPS unit O-GPS1 sold separately is available. ASTROTRACER correspondence
- Finder glass prism. 100% field of view. Magnification 0.95 times
- Adopting the same ocular optical system and the coating with the top model in the viewfinder
- The maximum speed of the shutter is 1/6000 seconds
- Continuous shooting up to 6 frames / sec (JPEG40 coma, RAW10 frames, RAW + 8 frames)
- Video is full HD60i / 30p. Stereo microphone built-in. Continuous AF
- 4K interval videos
- 3.0 inches Vari-Angle LCD monitor
- You can customize the display item in Control Panel
- The three user mode can be registered
- Wi-Fi built-in. Possible cooperation with smartphone
- 77-segment metering system
- Double Dial
- Media SD / SDHC / SDXC (UHS-I compatible)
- USB2.0 terminal. HDMI output terminal. Stereo microphone input terminal
- The battery is D-LI109
- The size of 125.5mm x 93.0mm x 74.0mm
- Weight 688 grams (including battery and memory card). 628 g (body only)
- Estimated retail price is ¥ 78000 (tax included)
final specs?
06-08-2016, 03:19 AM   #174
I think this is very clearly a model where they're testing the video AF. And a bit of refresh to the line. Nothing more. But gives time to prepare something more.
06-08-2016, 03:25 AM   #175
Imp
Imp's Avatar
QuoteOriginally posted by gazonk Quote
Better grip.
And speaking of the grip, are the moving towards a more Nikon-styled grip? It seems like from the K-30 to the K-50 to the K-70 its flaring out a bit more towards the lens mount, as if its covers your middlefinger. Having used a D7200 (once) I'm not certain I care for that... but I haven't used it long enough to really complain one way or the other. Just a thought. Maybe its better.
06-08-2016, 03:27 AM   #176
Mistral75's Avatar
US$675 actually. The Japanese price includes 8% VAT.
06-08-2016, 03:33 AM   #177
Imp
Imp's Avatar
even better
06-08-2016, 04:27 AM   #178
ogl
ogl's Avatar
Mixed K-S2+K-50 + new features...
06-08-2016, 04:32 AM - 1 Like   #179
Mistral75's Avatar
QuoteOriginally posted by ogl Quote
K-S2 + K-50 + K-1 features + brand new ones.
06-08-2016, 04:32 AM   #180
D1N0's Avatar
Why the huge IR receiver?
a6000, af, availability, battery, built-in, correction, ergonomics, flash, function, headphone, interval, jpeg, landscapes, lens, lenses, mic, pentax, pentax news, pentax rumors, pentaxians, people, post, sd, sheets, specs of pentax, sr, upgrade, video
K-S2 detailed review? JRMax Pentax K-S1 & K-S2 7 07-21-2015 09:12 AM
Specs of K-3II Daikokuya Pentax News and Rumors 780 04-26-2015 06:05 AM
Pentax K-3 Officially Announced (See our detailed preview here!) Adam Pentax News and Rumors 213 11-18-2014 01:46 AM
Macro Detailed photos of Pentax K-5 Silver special edition shaolen Post Your Photos! 8 05-30-2012 08:14 AM
Newbie needs advice on where to find detailed Pentax ist DL specs turay Troubleshooting and Beginner Help 1 11-24-2010 01:57 PM
All times are GMT -7. The time now is 12:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
