06-09-2016, 07:32 AM   #181
jatrax's Avatar
All of this may be a foolish worry over nothing.
+1 Thread closer.
06-09-2016, 07:37 AM   #182
QuoteOriginally posted by reh321 Quote
You'll notice that they don't claim K or M42 compatibility for any of those cameras, so they don't seem to be quite as wed to up-and-down the line compatibility as some of us are.
I was just curious why some of them have powerzoom compatibility and others don't have. And whatever powerzoom compatibility, they can become KAF4. It seems that I still don't understand the K-mount. I need to learn more.
06-09-2016, 07:38 AM - 1 Like   #183
Firmware requires hardware to operate, that is a basic truth. If the hardware needed is not present then the firmware cannot work, simple. Please don't leap to conclusions, of course no one outside of Ricoh knows the truth here.
But new functionality does NOT always require new hardware. (And things done in hardware can even sometimes be emulated in software.) So please, stating that because this is new functionality then it must require new hardware is just unsupported nonsense. There's just no way to know.
06-09-2016, 07:42 AM - 1 Like   #184
jatrax's Avatar
QuoteOriginally posted by Doundounba Quote
@Doundounba, that is not what I said or meant. Please read my post instead of jumping to conclusions. My original post said that, my second comment said that and now I'm saying it again. Firmware requires hardware to work, IF, the hardware is not present it cannot work. There, I highlighted the operative word for you. So if you want continue to be a jerk about this go ahead, I'm done.
06-09-2016, 08:11 AM   #185
Firmware requires hardware to work, if, the hardware is not present it cannot work. There, I highlighted the operative word for you. So if you want continue to be a jerk about this go ahead, I'm done.
I'm sorry but things just aren't that simple, and there's no need to resort to personal insult, as you have just done. (I have also removed the shouting from your quote.) The line between software and hardware is often movable. You can often emulate hardware in (lower level) software so that higher level software has no clue it's not talking directly to a piece of hardware, but to a lower software layer. Of course, this isn't always the case, and you do eventually hit the metal. In our case, it would be nice for Ricoh to release a technical paper on KAF4, so we can see how the mount works and how it has changed from KAF3...
06-09-2016, 08:18 AM   #186
Of course I do! I was not referring to this camera, but to firmware in general. Firmware requires hardware to operate, that is a basic truth. If the hardware needed is not present then the firmware cannot work, simple. Please don't leap to conclusions, of course no one outside of Ricoh knows the truth here.
If it's a hardware limitation in the K-3 then it must be quite arcane. Considering the K-3 II can send the necessary digital signal to the lens to control its aperture (once the firmware is updated), one would reasonably think the K-3 could do the same since they use the same processor and have the same contacts. Besides the processor and the contacts, what other piece of hardware is there in the digital signal generation?
06-09-2016, 08:20 AM   #187
Emperor and Senpai
VoiceOfReason's Avatar
I hope there are enough users here that we can petition them and have Adam or Kenspro send it along asking that the K3 at least be included in an update for KAF4, and possibly the K5 series too.
06-09-2016, 08:29 AM   #188
QuoteOriginally posted by IchabodCrane Quote
I'm just speculating here, but it could be that there are pins where the camera hardware was only reading voltage and now needs to set voltage, in order to communicate to the lens what is the chosen shooting aperture...
06-09-2016, 08:38 AM   #189
Imp
Imp's Avatar
QuoteOriginally posted by VoiceOfReason Quote
Kenspro
Kenspo
06-09-2016, 08:41 AM - 1 Like   #190
Emperor and Senpai
QuoteOriginally posted by Imp Quote
Kenspo
My fingers keep typing when my brain shuts off. I'd still like to get oen to take a request to include the K3 (it isn't like it is an obsolete one) and possibly the K5 and K50 series with an update.
06-09-2016, 08:44 AM   #191
This has been a fascinating thread to me.
Usually when I get into a discussion about AF, I'm advocating for good in-lens motors and everyone else is singing the praises of screw-drive
Usually I hear more good things about the K-3 than about the K-3ii; now it turns out that the K-3ii has some good points afterall.
06-09-2016, 08:49 AM - 1 Like   #192
I'm not an electronics engineer so will admit up front that I'm out of my league with these things. What I think I know is there's only one "pin" and that's the body to lens data pin. Signals must be multiplexed from the processor but that's still a single output point. If there's a reason why a K-3 II can properly multiplex the focusing with aperture signal but a K-3 can't, despite us thinking it's the same processor, it's not an obvious reason.
06-09-2016, 09:01 AM   #193
slip's Avatar
this is the first time I considered a lens like this because of the new autofocus...but no K3
Randy
06-09-2016, 09:05 AM   #194
It is very sad to see that the direction of Ricoh to continue with one of the characteristics but strong Pentax came to an end, compatibility with previous organizations.
I would be happy to see updates to K5 forward
06-09-2016, 09:16 AM   #195
I'm out of my league as well here, (and trying to educate myself between posts)... But AF gets its own pins, no? (The "SDM contacts", or do they just provide power?) I'm thinking this PF article will suddenly get a lot of hits.
aperture, bodies, body, cameras, capability, change, day, device, firmware, flagship, hardware, hd pentax-da, ii, k-3, k-mount, k100d, kaf3, lens, lenses, mirrorless, pentax, pentax news, pentax rumors, people, plm wr, portfolio, ricoh, sense, sigma lenses
HD PENTAX-DA 18-50mm F4-5.6 DC WR RE D1N0 Pentax News and Rumors 167 04-09-2015 10:03 PM
Pentax HD 55-300mm f4-5.8 ED WR lens: recognizing issue in Lightroom 5.6 lavie Pentax SLR Lens Discussion 2 09-10-2014 05:24 AM
For Sale - Sold: HD PENTAX-DA 1:4-5.8 55-300mm ED WR 55-300 (price reduced) transam879 Sold Items 6 07-15-2014 06:05 PM
All times are GMT -7. The time now is 10:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
