06-08-2016, 03:41 AM - 4 Likes   #31
Mistral75's Avatar
The aperture is controlled and commanded by an electromagnet and not a mechanical device. It's cheaper, more precise and allows for continuous and smooth variation in the aperture, which is a highly desirable feature in video mode.
All Canon lenses have such a device since the first day of the EOS system and so do all recent Nikon lenses (the "E" series).
Having the K mount allowing for electromagnetic control of the aperture is also important because it abolishes a barrier for third-party lens makers (think: Sigma) to produce K-mount versions of their lenses.
06-08-2016, 03:47 AM   #32
D1N0's Avatar
so this combinations is squarely aimed at 'soccer moms'
06-08-2016, 03:48 AM   #33
QuoteOriginally posted by Imp Quote
no more mechanical linkage? or does that mean something else?
We'll know when we get a look at the rear mount face and see what is or isn't there.
I notice that it appears to be about half a stop slower at both ends, too. The original was 4.0 to 5.8
06-08-2016, 04:02 AM   #34
aurele's Avatar
QuoteOriginally posted by Mistral75 Quote
Exactly ! I think it will also allow for cost reduction as the same aperture mechanism will probably be used in all next lenses.
---------- Post added 8th Jun 2016 at 01:05 PM ----------
Aha, so it IS built for video... the plot gets thicker
indeed
06-08-2016, 04:14 AM   #35
Mistral75's Avatar
QuoteOriginally posted by aurele Quote
Not yet, unfortunately, not until all then current bodies support this feature. And the future lenses with an electromagnetically-controlled aperture and no aperture-coupling lever will only be usable with K-70 and the following bodies.
06-08-2016, 04:20 AM   #36
Pentax 18-270mm
QuoteOriginally posted by Ole Quote
What about the DA 18-270? It is fairly compact so no need for the retractable feature and it exists today.
Thanks for the heads up, Ole! I'll check into that lens,....
Jack
06-08-2016, 04:22 AM   #37
Diameter increased from 71 to 76,5 mm
Length decreased from 111,5 to 89 mm
Weight decreased from 450 to 440 gram
# lenses increased from 12 to 14
# groups increased from 8 to 11
# diaphragms increased from 6 to 9
Focus group moved back
Close focus distance decreased from 140 to 95 cm
Focusing should be much faster
06-08-2016, 04:24 AM - 3 Likes   #38
QuoteOriginally posted by D1N0 Quote
Also known as "people who buy cameras."
06-08-2016, 04:28 AM   #39
Mistral75's Avatar
QuoteOriginally posted by Simen1 Quote
So they say themselves:
- Compared to the current 55-300mm, focus is 8.3 times faster on the wider angle side and up to 1.7 times faster on the telephoto side
06-08-2016, 04:29 AM   #40
D1N0's Avatar
This could be updated via firmware I would think. otherwise this new lens won't work on any body, unless it also has mechanical coupling.
06-08-2016, 04:31 AM   #41
Mistral75's Avatar
I presume it does since they write:
- High-precision exposure control in movie mode when paired with K-70
06-08-2016, 04:38 AM   #42
D1N0's Avatar
But it must be firmware since it doesn't have a different mount spec. It's KAF 3
06-08-2016, 05:00 AM   #43
Mistral75's Avatar
Where did you read a reference to K-AF3 in conjunction with K-70 or 55-300 PLM RE?
06-08-2016, 05:24 AM   #44
D1N0's Avatar
I didn't see KAF 4
06-08-2016, 05:32 AM   #45
Mistral75's Avatar
I didn't see KAF 4
Are you a lawyer, a politician or both?
aperture, bodies, body, cameras, capability, change, day, device, firmware, flagship, hardware, hd pentax-da, ii, k-3, k-mount, k100d, kaf3, lens, lenses, mirrorless, pentax, pentax news, pentax rumors, people, plm wr, portfolio, ricoh, sense, sigma lenses
HD PENTAX-DA 18-50mm F4-5.6 DC WR RE D1N0 Pentax News and Rumors 167 04-09-2015 10:03 PM
Pentax HD 55-300mm f4-5.8 ED WR lens: recognizing issue in Lightroom 5.6 lavie Pentax SLR Lens Discussion 2 09-10-2014 05:24 AM
For Sale - Sold: HD PENTAX-DA 1:4-5.8 55-300mm ED WR 55-300 (price reduced) transam879 Sold Items 6 07-15-2014 06:05 PM
All times are GMT -7. The time now is 06:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
