Originally posted by AggieDad Is all this new computing power going to result in a perfect capture every time? I mean exquisite (golden hour style) lighting, elegant framing, and perfectly timed wildlife shots.
If so, I'm all in. If not, maybe I'll just stay with my K-5IIs.
The
claim is that it helps in reducing noise.
I
believe that it is there to make the higher ISO settings useable.
The
proof will be in results from early adopters.
There would be no reason for you to get a "lesser" camera.
You didn't upgrade to K-3 or K-3ii, so there is no reason to expect you to "upgrade" to K-70, or even to whatever follows K-3ii, probably later this year.
If you are satisfied with what you have, you are allowed to continue to use it until a motor dies.
Others of us are allowed to feel differently.
