Is there any point in continuing this? Any argument I'm making would only strengthen your belief in the opposite (which is, unfortunately, a common human behavior).
OTOH your arguments are quite shabby, so they won't convince me.
"AF" is too generic; they did abandon the technical solution as implemented in the ME-F and the AF 35-70mm after a single try - because it didn't work. I'm not using broken analogies, I'm using as example
exactly the thing they did, and you're asking them to do again.
Let's be realistic, often Pentax products are rejected based on excuses - just for the sake of doing it. The K-01's design is atypical, not outrageously bad as it was described; the K-S1 LEDs don't make it a disco globe, it's still a capable little camera; and so on.
Your 2-3 years deadline is made up; I don't expect MILCs to even reach DSLR levels by then, less alone becoming the more lucrative market for Pentax. Even more, your solution won't put Pentax in a position to properly compete on the MILC market, as - your own claim - it would be made for existing K-mount DSLR users. That's inconsistent.
Once again: there is another way of entering the MILC market, than destroying the existing line; Canon proved that.
I'm not picking up part of the history, it's
you conveniently forgetting the claims
you were making; conveniently, because this way
you won't ever support
your own claims.
You said: "Pentax took 10 year to be there... Imagine if they have to restart from scratch. 10 more years.";
prove that they worked 10 years toward that goal, or retract
your statement.
So... is there any point in continuing this?
---------- Post added 08-10-16 at 02:38 PM ----------
Originally posted by Simen1 If Pentax throws the K mount overboard for a new APS-C or FF mirrorless camera, in order to reduce the register distance, I definitely wont buy into that new system. I'll rather keep having a K mount DSLR or if it gets weakened, I'll choose whatever that have a good ecosystem, and I doubt that will be Pentax.
That won't happen; we know as a fact that Ricoh Imaging is expanding the K-mount system. They wouldn't do that just to throw it away.
Don't panic.
