09-29-2016, 07:18 AM   #31
QuoteOriginally posted by hutchst Quote
File downloads to my Mac as fwdc228b-2.bin
You have extracted the firmware file twice, by the look of it.
The file name that you copy to the SD card should be fwdc228b.bin.
09-29-2016, 07:24 AM   #32
I have a Mac, so "extract PC" does not work
---------- Post added 09-29-16 at 06:40 AM ----------
I have followed very precisely the website instructions, using two different cards, but still have no success.
Hi Please check that the file name is exactly as described. If you have an earlier version of that file, Mac will add a *2* to the filename, and the camera won't accept it . I have done that bummer a few times myself
I deleted all earlier downloads from Pentax, dowloaded it again, so the file got saved by the correct name.
---------- Post added 09-29-2016 at 08:25 AM ----------
Sorry , seems like I was a bit late with my solution
09-29-2016, 07:27 AM   #33
You have to extract that zip file first.
09-29-2016, 07:29 AM   #34
D1N0's Avatar
Does the EFS also work in time lapse mode?
09-29-2016, 08:44 AM   #35
QuoteOriginally posted by D1N0 Quote
Not time-lapse.
09-29-2016, 11:17 AM   #36
PEG Moderator
Kerrowdown's Avatar
You have a -2 file marker. If you have a -2 extension you have an old FW update also on the card or in the computer folder. The update will only work if you first remove the old .bin file before decompressing. and from the card, then update from the clean .bin file.
Thank you... I was having exactly the same issue, your a Pentax hero.
09-29-2016, 03:50 PM   #37
QuoteOriginally posted by asahi man Quote
The system hanger is not anymore inside,everything clear.
I read that as system hangover... I need tea
09-29-2016, 04:02 PM   #38
Otis Memorial Pentaxian
clackers's Avatar
. File downloads to my Mac as fwdc228b-2.bin.
That isn't the filename the instructions say you need. 😊
09-29-2016, 05:25 PM - 1 Like   #39
RobA_Oz's Avatar
The"-2" indicates it's the third try to unzip the original download. Remove that from the filename, and you're good to go.
09-29-2016, 05:59 PM   #40
Class A's Avatar
Thanks!
button, camera, card, computer, download, drive, file, firmware, firmware version, instructions, k-1, k10, mac, mirror, name, pentax, pentax k-1, pentax news, pentax rumors, post, sd, settings, system, time, upgrades
K-1 firmware update version 1.30 shaolen Pentax News and Rumors 15 09-20-2016 06:38 AM
Ricoh just released K-1 firmware upgrade. v1.10 balapapapa Pentax K-1 & K-1 II 21 05-27-2016 10:30 PM
New firmware 1.10 for K-1 released funktionsfrei Pentax K-1 & K-1 II 2 05-19-2016 10:55 AM
Pentax K-7 firmware version 1.02 is out! inferno10 Pentax News and Rumors 17 10-25-2009 09:18 AM
firmware 1.30 released for K10D WMBP Pentax DSLR Discussion 6 08-09-2007 01:25 PM
All times are GMT -7. The time now is 02:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
