Show Printable Version 269 Likes Search this Thread
01-28-2017, 08:53 AM   #466
It's criticism for the sake of criticism, an extreme case of sour grapes perhaps?
It's not like we'd notice a slight creak in the K-1's grip, but would be completely oblivious to the KP's hand grip not being properly secured.
Some people are just professional FUD merchants or beaters of dead horses, and that's all there is to it. Looking at it cynically, if you can't put a grip on a frame and tighten a hex screw correctly, you probably don't deserve a thousand-dollar camera. (I just hope they chose a common, standard size for the key rather than some stupid proprietary diameter that has to be bought from the company.)
01-28-2017, 09:03 AM   #467
monochrome's Avatar
^^ The key (Allen Wrench) will either be Metric or SAE English Standard. Either way somebody won't have the right one.
01-28-2017, 09:21 AM   #468
reh321's Avatar
QuoteOriginally posted by ogl Quote
I trust in TWO screws.
I don't use neck strap with my cameras and I use hand strap with K-5IIs and K200D. Hand strap is a protection if my hand slips..
If you choose to not use the safety devices provided by the manufacturer, that is your choice, but don't blame them. Your original complaint about the grip is totally without merit - the KP is totally safe if you use the provided neck strap. I used my Super Program, with its tiny grip, without incident for eleven years, going through two straps in the process; one of my reasons for finally retiring it was that one of the anchors which the straps attach to finally came off.
01-28-2017, 10:19 AM   #469
mee
QuoteOriginally posted by reh321 Quote
Gentlemen, both ways of interfacing with your camera are correct. Neither way is incorrect. You can use a handgrip strap, you can use a neckstrap. You can even use both.
01-28-2017, 11:04 AM - 1 Like   #470
D1N0's Avatar
QuoteOriginally posted by Simen1 Quote
Look out for 3D printed and other 3. party crafted grips.. Maybe even some Hasselblad NEX inspired ones..
Or you can cut one yourself out of some Norwegian elk antlers
01-28-2017, 11:10 AM - 1 Like   #471
ogl
Banned
QuoteOriginally posted by mee Quote
or nothing to use
01-28-2017, 02:50 PM   #472
QuoteOriginally posted by D1N0 Quote
Hehe, I prefer reindeer, and actually have a couple of antlers laying around. Thanks for the idea
01-29-2017, 06:19 AM   #473
D1N0's Avatar
One Japanese store has already dropped the priced to the equivalent of $1000 (without taxes). http://shop.kitamura.jp/%E3%83%9A%E3%83%B3%E3%82%BF%E3%83%83%E3%82%AF%E3%82%...4549212298820/
01-29-2017, 06:24 AM   #474
You need a hex key (provided)
KP grip resembles Canon A-1 (film/FD) right-hand body grip (you needed a dime for a A-1 screw, but there was no IKEA in 70's ).
Motion bracketing is shutter speed bracketing; depth-of-field bracketing is aperture bracketing.
Still awaiting distance bracketing (present i.e. in some early non-digital EOS models).
I wonder if that will give the AF system a small performance boost
What makes me wonder if KP flash-shots delay will be equal to K3's 1/3 sec (which makes K3 + AF540FGZ unusable at weddings, children playgrounds, sports other than chess, etc.) or even longer
01-29-2017, 10:31 AM - 1 Like   #475
You probably should remove them from the elk first, though. Otherwise, you might end up with the new Pentax K-elk.
01-30-2017, 03:34 AM   #476
QuoteOriginally posted by Prakticant Quote
I never had any sort of delay with my flash on the K-3, but then again I use manual settings. I just underexpose a bit and correct in post for added leverage.
01-30-2017, 04:57 AM   #477
QuoteOriginally posted by CarlG Quote
No problem. Set the camera to interval, put on a grip with a full D-Li90, full battery in the camera, and let the elk go where it will. When you recover the camera, write the definitive coffee-table illustrated guide to elk migration patterns.
---------- Post added 30-01-17 at 08:27 ----------
Speed chess does exist - two minutes elapsed for each player to finish the game - so even that is not secure!!!
01-30-2017, 05:06 AM - 1 Like   #478
audiobomber's Avatar
QuoteOriginally posted by Sterby Quote
The delay is in P-TTL mode. It's annoying and sub-optimal. 1/3 second offset makes macro shooting with flash almost impossible for me. I would rather use my K20D with flash than my K-3, because it does not have the delay.
01-30-2017, 12:44 PM   #479
It might mean that ISO 51200 is finally usable, not just marketing.
I would be glad just forjust 25.600 for that price if noise is acceptable as I mostly shut at past afternoon and hate flashes but don't want to spend 4.000€ for a Sony A7SII + just 1 objective... and little body but big and heavy objectives (Ken Rockwell here us right)
01-30-2017, 12:56 PM   #480
QuoteOriginally posted by majortom67 Quote
Objectives?
accelerator, af, buffer, burst, camera, fps, grip, ii, image, improvements, iso, jpeg, k-3, k-3 ii, kp, pentax kp, pentax news, pentax rumors, pm, post, price, ricoh, sensor, shots, shutter, successor, system, unit
Pentax "KP" DSLR registered in Indonesia shakereduced Pentax News and Rumors 1319 02-15-2017 11:35 PM
Pentax K-S1 camera specifications i83N Pentax News and Rumors 46 09-01-2014 04:08 PM
Pentax K-3 Specifications Ayoh Pentax News and Rumors 420 12-21-2013 07:56 PM
Pentax MX-1 Full Specifications Adam Pentax Compact Cameras 48 01-14-2013 08:18 AM
Pentax K-30 Specifications Adam Pentax K-30 & K-50 113 07-08-2012 09:03 AM
All times are GMT -7. The time now is 03:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
