Originally posted by Nicolas06 What "considerably better"? K3 is already great. K1 is considerably better than K3, but still 1.5-2EV. K5 a bit better than K3. KP still APSC and likely based on Alpha 6300 or equivalent that is not much better than other APSC. This isn't CMOS vs CCD change man.
Yes a tiny bit more but likely less than if you invest in a lens that one stop faster, a great RAW processing software, a bigger sensor or a flash. I don't see it as KP would make a photo that K3 or K5 would break if you have a good workflow. Already people don't all agree on APSC vs FF that FF is really necessary, but there a bigger difference.
Good enoug is relative, but I guess 1600 iso on KP go to look better than 12800 on KP and 12800 on KP isn't going to look that great most of the time... So you still want to avoid 12800 isos when you can... Like you'd want to shoot at low iso when you can anway. What I know is that if I have to show high iso often, I'd buy an A7s or a K1 and ensure I have f/2.8 zooms and f/1.4 primes. I'd ensure I have the best raw processing software too and I'll invest into lighting equipment. I am not going to just buy a bit better APSC body.
Nicolas, you and I think a little differently - that's all
Yes, the K-3 is great. It's my main go-to camera, and regardless of these discussions, I'll more-than-likely stick with my K-3 and K-3II for some considerable time. However...
If the KP provides more detail and less noise than the K-3 at the same ISO, that should translate to better IQ through the need for less aggressive post-processing in Lightroom or similar. Let's not forget that with flash photography away from the studio, we may often need to shoot at higher ISOs in order to capture ambient light (your flash shots look fine, but would have benefitted greatly from a better balance with ambient light - for which you'd have to push up the ISO). If the KP produces equivalent detail / noise 1.0 - 1.5 stops higher than the K-3, that increases the number of situations where acceptable results can be obtained, and - more importantly - will mean a tangible improvement to every high ISO photograph. That difference may not be compelling to you... It is for me.
As for the high-res full-frame vs APS-C argument... I have full-frame and APS-C cameras, and with Pentax I
choose to shoot APS-C. The relatively compact and lighter-weight form factor of the K-3 is pretty much spot-on for me. I'm also very happy with the K-mount lenses I already own and use, and a number of those are either designed for APS-C format or perform much better on APS-C because of border performance. I don't
want to buy a K-1 (not at this point, at least), and despite the fact that I also own some big, heavy, fast zooms and a few fast primes in Sony A-mount, I don't want to buy an A7S either. I'm interested in how much better an APS-C sensor Pentax camera can be at higher ISOs.
Finally, we agree on something - "good enough" is relative. But whatever the level of IQ
you consider to be "good enough", it is likely to be 1.0 - 1.5 stops of sensitivity higher for the KP than the K-3. You may not find that appealing, but I do
