Closed Thread
11-04-2017, 04:55 AM - 3 Likes   #1996
Senior Moderator
BigMackCam's Avatar
QuoteOriginally posted by zapp Quote
I have a use for this lens and I am concerned about length, weight and filter diameter. The 85 will be even bigger that is my major concern.
Then I stand corrected
I tend to see the size and weight as a fairly simple recipe... as I've already suggested, the optical formula will largely dictate the length. The speed of the lens will largely dictate the diameter, and of course the size of the optical elements. The number and size of optical elements, along with the number and sturdiness of metal components, will largely dictate the weight.
The length, size and weight can all be reduced, but at some cost and compromise - different / simpler optical formula, slower maximum aperture, reduction of mechanical complexity, greater use of plastics instead of metal.
I guess the point I was trying to make - and should have made more clearly on my first attempt - is this: potential buyers who prioritise speed, optical performance and build quality will simply accept the resulting weight and dimensions. Those who would happily compromise on any of those elements may legitimately wish for a lighter and physically shorter lens.
11-04-2017, 05:08 AM   #1997
D1N0's Avatar
If you want a small 50 1.4 There is the FA 50mm F1.4 or the 43mm F1.9 limited. If you want a compact portrait lens, there is the FA 77mm ltd F1.8. Why would Ricoh make a bunch of similar lenses? We will have choice between compact and portable with great IQ and ultimate IQ but somewhat heavy and large. You can't have both unless you get both lenses.
11-04-2017, 05:41 AM   #1998
I wonder about that, and for the D FA* 35-or-whatever mm wide.
If they're all using the same ring-type SDM, and I mean the same - to reduce cost by not making different versions - the potentially smaller lens would be larger in diameter than necessary.
11-04-2017, 06:01 AM   #1999
Zygonyx's Avatar
QuoteOriginally posted by thibs Quote
The DFA/DA645 *25/4 was AW (as any star lens) and had the filter drawer so yes, that's possible.
DA560 also is AW and has a filter drawer.
Possible, but not useful : look at the deep filter shread in front of the 11-18mm.
11-04-2017, 06:08 AM   #2000
thibs's Avatar
QuoteOriginally posted by Zygonyx Quote
Oh, I guess the size of filters has no impact on price then....
11-04-2017, 07:48 AM - 3 Likes   #2001
JPT
QuoteOriginally posted by JPT Quote
I think you are probably right, and they are positioning this lens as the ideal companion for Astrotracer.
In the light of Yaotomi’s comment, it would be very interesting if the mystery switch on the lens turned out to be an on/off switch for an integrated heating element to prevent condensation on the lens.
Now I think about it, the switch being a zoom lock makes a lot of sense if this is a zoom lens designed to be suitable for astrophotography. It will be pointed upwards for long exposures, so the zoom lock would be necessary
11-04-2017, 09:15 AM   #2002
ogl
ogl's Avatar
The weight will be a result of the number of glass elements and metal components (i.e. "build quality"). The length will be largely dictated by the optical formula.
Those who have a genuine use for this lens won't be concerned about the weight or length
I had just gave estimated information and nothing else
11-04-2017, 10:46 AM   #2003
Zygonyx's Avatar
In any case peanuts compared to the lens price
11-04-2017, 07:24 PM   #2004
mee
It seems circular filter prices have come down quite a bit in the past few years.. or at least the budget ones have come up significantly in quality...
I would like to see more standard filter thread sizes on the entire lineup.. say 77mm or 82mm on the entire range. That way one can use a couple filters and skip the stepping rings. Plus, with the step rings, it means one cannot use their lens hood.
11-05-2017, 08:55 AM   #2005
Wow, what a relevation, I have the 55mm F1.4 works a treat on my K1 but an 85 seems miles or years away
11-05-2017, 10:17 AM   #2006
QuoteOriginally posted by D1N0 Quote
For people like me who are going to get full use out of my FF weather resistant camera. I bought into this system and will not buy another lens that is not weather sealed. They need a FF Nifty 50 that is weather sealed. They also need a FF prime wide angle that is weather sealed. I am not patient but I am determined, so I can wait
11-05-2017, 10:38 AM   #2007
QuoteOriginally posted by JamesDCrockett Quote
Isn't the 50 2.8 macro weather sealed?
11-05-2017, 10:52 AM   #2008
Zygonyx's Avatar
Unlike the last DFA 100 macro version.
11-05-2017, 10:53 AM   #2009
QuoteOriginally posted by awscreo Quote
Not according to BH. There is no WR or * designation either. So I would assume they are correct.
11-05-2017, 11:18 AM   #2010
I see. Then I guess we still have the 55 1.4) it's AW right? Should be pretty tough. I saw few on ebay for pretty reasonable amounts, below $500 used
Closed Thread
camera, drive, dslr, effort, f/1.4, f1.8, fa, im, k-1, lens, lenses, management, omega, opinion, pentax, pentax news, pentax rumors, people, photo, product, quality, ricoh, sigma, size, statistics, tamron, taste, theory, time
Diglloyd reviews DA 35, DFA 50 and DFA 100 Macro lenses on the K-1 Matchete Pentax SLR Lens Discussion 19 06-09-2016 09:18 AM
Sigma 50/1.4 EX vs. Pentax FA 50/1.4 and DA 55/1.4 DonovanDwyer Pentax SLR Lens Discussion 17 01-24-2014 12:54 PM
For Sale - Sold: Sigma 10-20mm/4, Pentax FA 50/1.4, DFA 100mm/2.8 Macro Alam Sold Items 5 11-20-2011 03:02 PM
All times are GMT -7. The time now is 07:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
