I'm just pointing out the disconnect between the actual posts and what he's been accused of.
It's reasonable to assume the new ring-type SDM would be somewhat faster than a DC motor (on a similarly built lens), because otherwise it makes no sense to use a new motor (DC is pretty much bulletproof). Assuming the AF would work much better than on the manual focus Zeiss is not wrong, either ;-)
By the way, how do you evaluate sharpness if not by looking at photos?
---------- Post added 14-12-17 at 12:46 PM ----------
Originally posted by Rondec
At the same time, I don't even know why that's a big deal in this focal length. It isn't like you are going to be shooting sporting events with a 50mm lens -- at least, I wouldn't think so...
I'd say, this is not as much about the lens' usage - but rather about it being a high margin product which can include this technology.
Likely, the D FA* 85mm f/1.4 and maybe the D FA* 35mm f/1.4 (if that's what it will be) would use the exact same ring-type SDM; thus building up some volume on this expensive component.
