Originally posted by Na Horuk (...)
Originally posted by Mistral75 JPT, thank you for providing this summarised translation. I would add a point that you left aside in your summary: the lens is a macro lens in the sense that its maximum magnification is 1:1 in terms of 35mm format..
I'm not sure that was clear. I expect the magnification of the photo with this lens at MFD will be similar to DFA 100mm on a K-1 at MFD.
It might have been clearer, had you quoted (and read?) the first sentence from the second paragraph of my message:
Originally posted by Mistral75 At minimum focussing distance, which is around 14 to 15cm, Tanaka says the coverage is around 25 x 36mm. (...)
Kimio Tanaka has written, and I have translated, that the coverage (you say magnification) of a photo shot at the shortest focussing distance is similar to that of any macro 1:1 lens on a 24x36 camera (there will be a slight difference due to the difference in the sensor's aspect ratio, 4:3 versus 3:2).
To write it differently: the lens on a Q7 or Q-S1 has the same angle of view / coverage as a 92mm on a 24x36 camera, from infinity to the minimum focussing distance.
There will be a difference in the depth of field though, much bigger with the 09 Telephoto Macro than with a 90mm macro lens on a 24x36 camera set at the same aperture, this rather being an advantage in proxy- and macro-photography.
