Show Printable Version 27 Likes Search this Thread
10-17-2017, 12:58 AM   #61
If they do, would you buy them BOTH?
I don't think you would buy any of them. Given real world restrictions - the G1 X Mark III's lens is not slow, is as big as they could put into the camera - there will be room for nitpicking... and then, there's the price issue.
A "24-100" f/2.8-3.5 would be significantly larger, and there's nothing Ricoh Imaging could do about that.
Do you remember the film era compacts? With their f/8-11 (at the tele end) zooms? Those were slow.
10-17-2017, 01:42 AM   #62
Digitiser of Film
BigMackCam's Avatar
QuoteOriginally posted by ogl Quote
G1 X Mark III is weather sealed APS-C camera with zoom for travel.
Small, light and tilting LCD, but ugly, expensive, slow battery and slow zoom.
Ricoh must produce TWO new GRIII 24 MP with fixed lens and with faster zoom and weather sealing....Alas...No any rumors.
But you simply can't have a large sensor compact with a fast, integrated zoom lens. There has to be a compromise, Boris - whether it's the size of the camera and lens, the size of the sensor and / or the speed and focal length range of the lens. Large sensor + fast, integrated zoom lens = non-compact.
When camera makers find a way to defy the laws of physics and produce what you're asking for, I'll be at the head of the queue
10-17-2017, 02:45 AM   #63
ogl
Banned
A "24-100" f/2.8-3.5 would be significantly larger, and there's nothing Ricoh Imaging could do about that..
man, there are technologies to make folding lenses compact and rather fast for bigger sensors, GR's 18/2.8 is very small.
we don't know if it would be significantly larger until we see such lens. don't compare with DSLR lenses.
this camera is not pocket size, that's why if the lens will be a bit bigger is not a problem.
it's slow for me. 24-70/2.8-5.6 is not slow for you. taste differs.
10-17-2017, 02:51 AM   #64
ogl
Banned
Why? We say about special folding lenses for compact camera, not for classical mirrorless or DSLR.
And we say about reasonable compromise between aperture, size and focal range.
If Ricoh can produce shorter, but compact and faster lens in new GR, it's better for me than Canon's lens.
10-17-2017, 03:01 AM   #65
Digitiser of Film
BigMackCam's Avatar
man, there are technologies to make lens compact and faster for bigger sensors, GR's 18/2.8 is very small.
Lens design has certainly allowed for reduction in lens size, but there's a huge difference between an 18mm f/2.8 prime and, say, a 16-50mm f/2.8.
If you can, show us a small, collapsible, fast zoom lens that covers the APS-C image circle. I don't believe such a lens exists... not small enough to incorporate in a compact camera, certainly.
The only difference between that G1X MkIII and any other APS-C camera - DSLR, mirrorless, whatever - is the flange focal distance and fixed lens. Lens design and physics don't change - they are the limiting factor.
10-17-2017, 03:01 AM   #66
Ogl, I've seen enough lenses (not only DSLR ones) to have a reasonable guess at what might be, and what might not be feasible. And the argument from ignorance doesn't work with me: you should prove that it can be done.
The 18mm is a prime; the 15-45mm is a zoom. Apples and orange trees.
If you only care about numbers but not actual performance, you can get "f/2.8" with a much smaller sensor.
10-17-2017, 03:16 AM   #67
ogl
Banned
I don't say about folding 16-50/2.8...
10-17-2017, 03:19 AM - 1 Like   #68
Digitiser of Film
BigMackCam's Avatar
That's an f/3.5-5.6 lens, Boris. Typical, slow-ish kit zoom. The Canon already has that...
10-17-2017, 03:36 AM - 1 Like   #69
IMHO a rather short zoom range would be sufficient.... on a FF compact...
and since you guys doubt that a rather fast digital FF zoom compact-camera can be done...
... I want to suggest you to take a closer look at the added picture and google 3 words ---> FUJI NATURA CLASSICA!!!!!
the cam is: 109.5mm×62.0mm×36.0mm
the Ricoh GR is: 117mm×61mm×34.7mm
so it should be possible to keep a FF RICOH GRZ(oom) nearly at the same size.
and NO, NO, NO... this is not an APS camera.
I have absolutely no idea, what could be difficult in making such a design digital...
and when I am thinking about how technology and everything evolved, I am sure that lens design could be improved.
Though, I would be totally satisfied with the 28mm-56mm F:2.8-5.4 lens also...(fast enough for me and though not a very long reach, still more versatile than just a 28mil wide a.)
If you need more examples on small compact zooms, search for yourself.
(Especially because sometimes on pentaxforums.com the motto seems to be: "Let no good deed go unpunished...")
10-17-2017, 03:53 AM   #70
Digitiser of Film
BigMackCam's Avatar
QuoteOriginally posted by camyum Quote
I know that camera rather well... I lusted after one, for a while
The lens is small because it's a slow f/5.4 at the long end, with a rather limited focal length range of 28-56mm... wide-angle to more-or-less normal. I've never doubted that a lens with those design limitations can be small. That said, Fuji did a great job, and I'd be happy with that lens for a lot of photography
I do think, though, a compact, do it all, fixed lens camera needs to offer wide-angle to short-tele, otherwise it becomes narrower in its application and will have a smaller potential market.
10-17-2017, 04:23 AM   #71
ogl
Banned
Yes. It's lens for mirrorless camera. I think It's real to make such lens for GR faster and not bigger.
10-17-2017, 04:25 AM   #72
ogl
Banned
28-56/2.8-5.4 and compact FF like this Fuji is cool
10-17-2017, 04:54 AM   #73
Digitiser of Film
BigMackCam's Avatar
How? How do you get past the physics, Boris?
There are very good reasons why no one has created such a lens yet. Just because the GR is compact, that doesn't change the laws of lens design. The format of the camera makes no difference... The GR is just a mirrorless camera with a fixed lens. The size of the lens is - to a great extent - affected by the focal length range, aperture, image circle size and flange focal distance (plus, of course, the optical formula).
You can have (a) a small-ish, fast zoom lens for a small sensor, (b) a small, slow zoom lens for a large sensor, or (c) a larger, fast zoom lens for a large sensor. What you can't have is (d)... a small, fast zoom lens for a large sensor. If you really believe that's possible, you must know something that conventional lens and camera manufacturers don't.
10-17-2017, 05:54 AM   #74
ogl
Banned
What about upper post about 28-54 ?
10-17-2017, 06:25 AM - 1 Like   #75
A 28-56mm f/2.8-5.4 is fine and "cool", but a 15-45 f/2.8-5.6 is slow?
The Canon lens is APS-C; OTOH:
- it's made for high resolution digital sensors
- it's wider
- it has a wider range (3 times, as opposed to less than 2)
So: how do you get past the physics?
camera, forum, gr, length, pentax news, pentax rumors, replacement, ricoh, ricoh grz, rumor
Metz mecablitz 26 AF-2 coming soon acoufap Flashes, Lighting, and Studio 8 01-16-2020 03:29 AM
Nikon D850: New FX-format digital SLR camera coming soon. interested_observer Canon, Nikon, Sony, and Other Camera Brands 301 12-18-2017 09:05 AM
Thematic "Show me your Pulitzer" contest coming soon charliezap Mini-Challenges, Games, and Photo Stories 4 10-08-2010 03:09 AM
New models coming soon. Return recently bought K-x? Muse Troubleshooting and Beginner Help 25 09-03-2010 09:18 PM
Samsung pancake NX 20mm f/2... coming soon!!! Xian Canon, Nikon, Sony, and Other Camera Brands 18 06-18-2010 02:08 AM
All times are GMT -7. The time now is 11:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
