Originally posted by H.Abendsen gosh... wtf? still dont understand why:
a) turning one dial around until it is in the right position
b) then selecting the ISO with an extra dial
should be any faster or more "tactile" than to
a) just hold the iso button on top of the cam with the index finger and turning the "rear e-dial" in one move only... pls explain...
I think you are making wrong assumptions because you just dont know the ISO button on the old flagships, since you own a K-30...
Its OK if some think, that those wheels make sense, especially if they never read the manual of a K-7/K-5 or used another (DIGITAL) PENTAX flagship camera onwards from the K-7 era.
But from my point of view, it is a fact that we had the most easiest cleanest design on DSLRs when PENTAX introduced the K-7
and all the bodies afterwards up to the K-3 kept that and offered that beautiful uncluttered design.
Everything on those cameras made perfect sense... (K-7 | K-5 | K-5II | K-)
Despite selecting the focus point, you were able to make lightning fast adjustments to ANY of your settings, given you read your manual.
And despite some incy wincy details, like the AF-Button BigMackCam mentioned before or the lever(left instead of right) direction, I dared to note in some former post. - but those are things not worth mentionin...
but i read and heard from a lot of people by now, that those wheels dont really please them and they find em distracting...
Mostly (semi-)professional people who own a K-1 or already rented one... would give both wheels
(and maybe the first segment of their lefthand little-finger)
for having a thumbstick instead with which they could easily select the desired focus-point(/area). bet something on that.
And no offense here, but: People who praise that wheel-cluster-design the most, often seem to not even own or use a K-1.
- yes i used it for street, portrait, etc...
and even though i just hopped in and registered, i know the forum very well already, so it seems to me that some members would also praise the K-1 even if it had a colorchanging glowing ping-pong ball instead of an info display and 4 more wheels.
people have been arguing in here about that before.. i read that. what happened to them?
I guess kicked out in favor of some forum-behemoths... so i wont comment on this issue any further, no matter what you will answer, jatrax...sry.
You've taken a position and now you appear to want to defend that position to the end.
OK, I'll play. I shot a K-5 from 2012 to just the other day. Then, thanks to Adam's generosity, I got to experience the K-1ii.
On the K-5, to select AF points, was relatively easy. On the K-1ii, it's as easy. Push AF mode button with the left index finger and spin the front wheel to toggle between AF.S and AF.C, or the rear wheel to select the different AF point options, using the four way controller, as on the K-5 to move to a specific AF point. For someone coming from a K-5, this is a very easy and intuitive solution. No thumbstick needed or wanted by this user.
How often do I look at the top display? Very seldom is the answer. So, do those two wheels help or hinder? For the ISO setting and the EV compensation I don't need it, as I'm used to the location of those two buttons - same as the K-5.
So, how about the rest?
CH/CL---Very handy to quickly change from single frame shooting to continuous. Pretty nice to get to that without delving into the menus.
BKT-------Very handy for choosing between bracketing and single frame shooting. Pretty nice to get to that without delving into the menus.
HDR------Perfect for HDR shooting. Pretty nice to get to that without delving into the menus.
Grid-------As I like the grid lines in the viewfinder, I don't see the need to turn these on or off. So, a bit of a wasted button position for me.
SR--------Shake Reduction on or off. Pretty nice to get to that without delving into the menus.
Crop-----Don't need it.
Wi-Fi----Brilliant. Real nice to get to that without delving into the menus.
If I had to pick between having the wheels or not having the wheels, and having a bigger display as per the K-5. Tough choice really. I feel there could have been a hybrid option that has not been explored where, upon turning the Smart Function Dial, the rear wheel (coloured red in my indicative sketch below) automatically takes the function of the secondary wheel. This would give space for a larger display screen up top and would look quite nice in my view.
