Originally posted by MarkJerling I have an older Windows 10 Pro 64-bit laptop, Intel Core i7-2820QM CPU @ 2.3GHz, 8GB Ram and an NVIDIA Quatro 4000M Video and it runs perfectly fine with Lightroom. What it won't do is stitch 6x K-1 files in Lightroom, but other than that, all functions work perfectly and no delays. Image Composite Editor is happy to do the stitch for me.
Apart from the stitching issue, the jump in file size from the K-5 to the K-1 has made no noticeable difference. The stitching issue may be due to some other factor, but I suspect that is a file size issue. But I've not dug deeper to see if I can solve it.
I admit, i maybe overdoing it sometimes.. but since we take photos in non-lossy formats with whoknowshowmuch-bits...
I tend to only work with TIFF files that i develop in lightroom(or silky) from pef-raw files.
I also oversize the pictures because doing retouching on oversized images makes retouching much less obvious in the final result when you resize it back to a normal size.
And convert the result back to TIFF again.
And if lightroom is opened with the fat catalogue with loads of K-1 PEF RAWs.
and i work with a load of layers in Photoshop. I experience that the system is slowing down.
(Especially with something else maybe running in the background.)
Of course... If you convert your files into JPGs and color profile to mere RGB and therefore kick everything like:
details
microcontrast
depth ...so nearly every of the image quality advantages that come frome such a high resolution high bit-depth sensor...
... into the trash can...
than yes... things are as fast as when you would work with K-5 files. of course... but that is not the reason why I bought a K-1.
Honestly I really dont dare to pixelshift too much. Because the files get even bigger.
And for that very reason, I vote that the resolution for upcoming FF cameras should not be raised too high nor should it be lowered distinctly.
But not really being a great fan of lowering MP, i would not be too depressed even if RICOH would really dive into the "CAMERA for the MASSES"(A7III/S1) competition with a 24MP FF camera.
Since with 24MP i WOULD DO pixelshift my product-photography shots...
Because despite all the talking about landscape... I think this is where PENTAX-Pixelshift really shines:
Product-Photography... Because in a studio product shooting, there is no wind, and since the schnitzel on the plate is already dead or the Vinyl-Deck you take a photo of is switched off - yep you got it - nothings moving and since that is so: Pixelshift makes the most sense here.
And when I pixelshift my 24MP photos and do a bit of resize-trickery that uses the non-interpolated info from the PS-RAWs, i can reach the same results i could reach with a Canon 5D IV(app. 32MP) and that is quite enough even for the finer CMYK-billboard prints.
42mp would be quite right... but i really see that is where reasonable FF resolution hits the ceiling...
of course... there are sensors that could do much more... but where are the lenses for those sensors...?
even really pricey Canon glass shows its limits on a 5Ds - If you want it to make sense you can only feed such a camera with lenses that cost about 3000 dollars each...namely Zeiss OTUS.
I gotta admit the new DFA* 50mm 1.4 is already nearly there... but I guess at some point above 50mp of pixel-density on FF ... even the best lens starts bleeding.
---------- Post added 10-01-18 at 11:13 AM ----------
Originally posted by surfar OH,didnt they?????
Samsung came out and publicly stated they wanted to sell sensors for cameras,they saw Sony having all the market(apart from Canon) and wanted a slice.It was late last year or early this year.
The "rumour" is from Korean sites,I suppose Samsung being Korean might have something to do with that.
Its either true or not...50/50,Fuji was linked in the same rumour.Their latest body features a BSI sensor from a unconfirmed source.Samsung has been known to make those sensors.
If Ricoh does have a sensor + processor from Samsung(?) its a good thing.
I like that idea too...
and there has got to be a reason, that no one dared to ask such a question at photokina, but Baus had that big smile, when he said,
that even many K-1/K-1II owners, will see a desirable camera in the upcoming APS-C DSLR
If i would have to throw in my 2 cents, i would guess it will be something like the A6500 but with a mirror and 2 card slots. (maybe even one XQD of CFExpress just like the upcoming Pana FF)
