Closed Thread
Show Printable Version 1279 Likes Search this Thread
11-13-2018, 04:15 AM   #2386
Merv-O's Avatar
QuoteOriginally posted by Larrymc Quote
About half of my lens are DA and at my age I really don't need to be investing a lot of money in different lens that's why I didn't buy a K-1 after their price dropped. I've given my daughter my K-50 and some lens so other than my little Panasonic FZ35 and my film Minolta XD11, I'm down to a lightly used K-3 with less than 20,000 shutter actuations. When a new High Spec APS-C body hits the market, I'm grabbing it and plan to have it and the K-3 as my last cameras.
I understand. the K-3 is a solid camera. I'm selling men due to the backward compatibility in the K-1ii (you can have APS-c and FF views in one camera) and use both DA and AF lenses, for my purposes, the K-3 is now redundant (I bought a leftover new K-S2 so I can travel, light and allow my daughter to learn more about photography). Speaking of the K-50....I had one for several years and some of the photos I took with that are still hanging in my office. Excellent clarity and IQ for its time.
11-13-2018, 04:21 AM   #2387
QuoteOriginally posted by reh321 Quote
So, your figures assume having the main LCD turned off?
The back LCD is a small contributor only. Although, when shooting sports, burst mode, we have the eye stuck to the OVF most of the time and settings fixed in advance, thus possible to save some battery energy by having the back LCD switched off.
11-13-2018, 04:25 AM   #2388
ogl
Banned
That's because power management tends to improve with newer models. .
He said about K-5.... If I'm not wrong...
11-13-2018, 07:51 AM - 1 Like   #2389
What I like about having the K-3 II and the K-1 II is that I can get the aps-c distance with approximately 24 megapixel with the K-3 II, and with the K-1 II I have the 36 megapixel for closer subjects at the full frame level. For example I could use the K-3 II with my Sigma 150-500 DG OS for birding and my K-1 II for portrait or other closer distance subjects with my Pentax 70-200. The K-1 II is capable of cropping at approximately 16 mp, but the K-3 II yields the 24 mp at that crop. It all depends on what the user wants to shoot. If a new aps-c comes out with more megapixels than 24, it will be valuable for distance for birding and wildlife for example.
11-13-2018, 02:33 PM   #2390
Merv-O's Avatar
QuoteOriginally posted by C_Jones Quote
True: the K-3 shoots at a 24mp crop, but the pixel size and absorption of the K-1ii will still produce a superior image. I took with the K-1ii and a old 50-200mm plastic Pentax kit lens....the Bokeh and the density of the detail is as much or more than my K-3 or my K-S2 (20mp). The IQ, the firmware and the technology of a 2018 design just overwhelms the K-3 series at this juncture. Don't misunderstand, the K-3 is more than enough camera for most applications, but it is overshadowed by the K-1 series.
11-13-2018, 02:38 PM   #2391
Yes, I was talking about K5 (also valid for K5iis).
And the 1500 is VERY conservative, and I don't have the LCD off, I just have the auto-power off at 1 minute. No flash. Reasonable percentage at 800+ ISO, and that is noticeable in battery life.
I do some reviewing/deleting every now and then.
I have 3 Li90 [for K5 and K5iis], 2 are from when the K5 came out. Don't know how many years that is, but both cameras are way over the rated shutter life, so they've seen more than a few full cycles (I try to avoid that now as I notice a performance drop coinciding with the first drop in the battery meter, and it's not good for the battery).
At the end of the day I'd have 1 empty battery, move the half used from primary to secondary camera, and also charge the one in the secondary (was at 1/2). This was for 3000+.
I you're getting the CIPA or less, and not being heavy on flash, I'd say you have a problem.
Or a very demanding use of battery
11-13-2018, 02:51 PM   #2392
microlight's Avatar
K-3 overshadowed by the K-1 series? Not surprising - they’re different formats. Like saying the 645z overshadows the K-1. Apples and oranges...
11-13-2018, 03:33 PM   #2393
Merv-O's Avatar
QuoteOriginally posted by microlight Quote
Let me clarify K-3 "overshadowed" by the K-1 series. In the 4 years since the K-3 was designed, RIcoh created additional, improved technology that simply makes the images pop. Even in the 15mp crop mode on the K-1ii, the images are beautiful and clean, particularly in raw, with less noise than most K-3 series photos at similar aperture and speeds. I like APS-c formats, I'm talking simply about IQ. If Ricoh/Pentax makes a K-1ii APS-c camera, that would be a great evolutionary tool. The screen would articulate, the stabilization would be 3 stops faster , the focus would improve, and you would have a true "mini-K-1".
The K-3 limits are not in its format, it in its technological limits as a 5 year old design. Still, it renders excellent pictures with the right person at the controls.
11-13-2018, 04:07 PM - 2 Likes   #2394
Otis Memorial Pentaxian
clackers's Avatar
QuoteOriginally posted by Merv-O Quote
Well, the K-3 sensor is newer than the K-1 sensor, Merv, the K-1 has old tech, basically a double sized K-5 wafer, you can see that in DxO measurements, and it's why it's priced so attractively.
Like the KP, the K-1 II does have the pixel shift option for static subjects, and that onboard noise reduction chip kicking in after ISO400, which some people like and some people don't.
11-13-2018, 04:46 PM - 2 Likes   #2395
microlight's Avatar
Thanks for the explanation, Merv-O, I understand the point that you're making, although to me, image 'pop' is substantially influenced by the lens in use, as APS-c Limited and DA* users will attest. So this is not just down to improved technology IMHO. IQ isn't only about image 'cleanliness', it's also about resolution (where the K-3 bests the K-1 in crop mode), contrast (where the lens used comes in) plus a lot of other factors. So while it's clear that you're enthusing about the K-1ii (and why wouldn't you?), don't forget that these are indeed two different formats; holistically they have their individual strengths and weaknesses and it would be invidious to apply the same expectations to both. I'll take you back to the comparison of the K-1 with the 645z - the latter is an older design than the former (same approximate vintage as the K-3 in fact), and there are advantages and disadvantages to both of those formats, as there are with the 35mm and APS-c, and in pretty much the same areas. It's like saying that a car overshadows a motorbike because it's got more wheels.
You'd expect me to defend the K-3 - after all, this is the 'K-3II replacement' thread! And if the mooted replacement does turn up next year with some of the K-1ii tech in it, then that would be great, and who knows, the K-3II could become my second camera...
11-13-2018, 05:58 PM   #2396
so if Pentax were to sell a 24mp FF camera below $1300, I am in a position to consider it without purchasing any other lenses ....
What about a used K-1, 36mp with a 16mp Apsc built in(you are used to 16mp)....K-1 is rated for 300k accutations.
11-13-2018, 06:04 PM   #2397
reh321's Avatar
QuoteOriginally posted by surfar Quote
My preference right now is for a KP - I was simply saying that I can think of things that Pentax could do with a 24mp FF sensor that would grab my attention - so I'm putting off my decision until I see what does happen in the next year.
11-13-2018, 06:17 PM - 2 Likes   #2398
The Squirrel Mafia's Avatar
Very wise decision. Next year is only a month & a few days away. Then CP+ will arrive at the end of Februeary. Ricoh will probably reveal their "playing cards" around then. Like they say, "Good things come to those who wait."
11-14-2018, 02:00 AM   #2399
Hello, the sounds heard at the photo show in Paris make me think that 2019 should bring us something nice in APSC. the 100 years of Asahi are a great opportunity! Will we have a K2? In a quarter we should know a little more Wait and see !
11-14-2018, 05:25 AM   #2400
ogl
Banned
QuoteOriginally posted by dafbp Quote
It's funny story. If I have CIPA level's shots is normal. It's not a problem. Your story is unique for Pentax cameras. I had K-5 too and several original D-Li90 and never heard such fabs. Yes, I can get approx. 1000 shots with manual lens. And I know such users. But 1500+ with AF-C - you can't prove it.
Closed Thread
50mm, 85mm, adapter, angle, aps-c, battery, camera, camera list, canikon, depth, gap, k-3 ii, k-mount, k3, lens, lenses, list, mirrorless, mount, pentax, pentax news, pentax rumors, pool, products, ricoh, ricoh japan, size, wonder
DA 18-55 WR replacement on K-3 II CharLac Pentax SLR Lens Discussion 19 04-19-2018 08:29 AM
Pentax K3ii officially discontinued dcpropilot Pentax News and Rumors 509 03-05-2018 09:25 AM
K3ii replacement 36mp? amp Pentax DSLR Discussion 35 02-21-2017 10:17 PM
Successor to K3ii - care to guess when? Spodeworld Pentax K-3 & K-3 II 178 11-12-2016 01:57 PM
Replacement K3ii also under affected serial Numbers khilla Ask B&H Photo! 2 07-23-2015 11:12 AM
All times are GMT -7. The time now is 04:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
