Closed Thread
09-15-2018, 05:42 AM   #1276
I'm not a metallurgy expert, but until we find one I'll offer two guesses:
- it's easy to work with
- it's light
Of course, "aluminium" is way too generic - aluminium alloys can have very different properties. Just like there isn't a single "plastic".
09-15-2018, 05:54 AM   #1277
Banned
QuoteOriginally posted by house Quote
I've always found that to be quite an odd choice. It's so soft and malleable, not properties I'd think would be good for the barrel of a lens. Any metallurgy experts out there able to explain the possible rationale?
I think the key to this is......Don't drop lenses....
09-15-2018, 06:28 AM - 3 Likes   #1278
photoptimist's Avatar
- it's light
Yes, aluminum is light and easy to work with. But one of it's biggest advantages for lenses and aircraft is that it does not rust, corrode, or tarnish under a wide range of conditions.
As a chemical element, aluminum is more susceptible to oxidation than iron/steel, copper, silver, etc. When aluminum is cut or scratched, it does oxidize rapidly. But that oxide forms an extremely hard layer -- it's basically sapphire -- which then protects the bulk metal underneath.
09-15-2018, 07:09 AM   #1279
reh321's Avatar
QuoteOriginally posted by RonHendriks1966 Quote
.... nor camera bodies.
09-15-2018, 07:30 AM   #1280
Larrymc's Avatar
Way too much logic.........
09-15-2018, 08:06 AM   #1281
Not a metallurgy expert..
Pure aluminium is soft and malleable[ish]. Aircraft wings made of it would just bend for a while, then fall off with fatigue cracks...
However, aluminium alloyed with the required small quantities of other elements becomes the stuff you do make aircraft from... ...and it's pretty good for other uses too. Fibre reinforced plastic will do the job too. It's not what something is made from, but how well that material is suited for the product. Strong, light and resistant to various environmental hazards ticks many boxes for both aircraft structures and camera bodies.
09-15-2018, 09:33 AM   #1282
Mark Ransom's Avatar
I've done that, twice. I can verify that you don't want to do this.
09-15-2018, 11:26 AM   #1283
At the risk at nitpicking or even being wrong: before aluminium is cut it will already be covered by a thin oxide layer. A cut will expose 'bare' aluminium that will then oxidize. The good thing is that the type of oxide aluminium forms is only on the surface, and will not penetrate and degrade the material below it. In that sense its quite different from iron oxidizing. I do think that the ease of machining and weight also play an important role in the decision to use it for lenses. Otherwise, stainless steel could be a good alternative, which would be less damage-prone. I have no clue if other things such as thermal expansion coefficients etc. come into play when making these decisions.
09-15-2018, 01:19 PM - 1 Like   #1284
Yup aluminum oxide just a little softer than silicon carbide.
I also have done a lot of anodizing for a lot of the aluminum parts that I have fabricated over the years. Never did perfect color anodizing yet.
Just don't leave a copper penny in the bottom of your aluminum boat and go sailing on the ocean
09-15-2018, 01:33 PM   #1285
reh321's Avatar
QuoteOriginally posted by Mark Ransom Quote
My daughter managed to ruin a camera by carrying it in her book-bag - turns out that the electronics is the most fragile part ... shock will destroy electronics {especially LCD} even if the case is intact.
09-17-2018, 12:28 PM   #1286
reh321's Avatar
While walking this afternoon I remembered a Samsung P&S I had in the early 1990's. Of course, the case was all plastic - I know there was some metal inside, but I don't know how much. In 1995 my wife was team-teaching a low-level chemistry course, and she asked to borrow that camera so they could document some of the work they were doing; that evening she told me that they had dropped it on a 'hand off'. There was no external damage evident - but it never focused accurately again {of course, AF was the only focus available on a camera like that} ..... apparently the plastic shell had handled the fall better than the internal parts had.
09-17-2018, 12:58 PM   #1287
xmeda's Avatar
hmm.. still no camera.. or more likely no other new product this year than 50/1.4 and finished K1
sad.. others are able to deliver 5+ lenses and several bodies each year..
09-17-2018, 01:06 PM   #1288
reh321's Avatar
QuoteOriginally posted by xmeda Quote
Still not end of Photokina.
Sad that you give up so easily.
Photokina, Ricoh has Confirmed - PentaxForums.com
09-17-2018, 02:55 PM - 1 Like   #1289
Digitiser of Film
BigMackCam's Avatar
Alas, I think you're comparing directly to other brands in the ILC market, instead of acknowledging the limited size of the Pentax team or division within Ricoh Imaging.
You're going to be continually disappointed in Pentax if you keep up with that comparison. The pace of development and release is going to be relatively slow, and result in fewer products to market, than the big boys such as Nikon, Canon and Sony. Smaller budget, fewer employees and - I think we can safely assume - lower revenue and profit targets (combined with lower business risk). That's not going to change any time soon, if ever.
If Pentax doesn't provide what you need or want, or move at a pace that you can live with, the sensible choice is to go with another brand. I think we'd all like things to be moving a little quicker at Pentax, but consider that for many of us, we're still pretty happy with the way things are going, and can see reasons why Ricoh is limiting investment and managing business risk accordingly...
09-17-2018, 03:00 PM - 2 Likes   #1290
QuoteOriginally posted by reh321 Quote
Where is Sony's Photokina announcement? Where is Olympus'? Panasonic's?
Maybe all those companies closed shop and we didn't notice
Closed Thread
50mm, 85mm, adapter, angle, aps-c, battery, camera, camera list, canikon, depth, gap, k-3 ii, k-mount, k3, lens, lenses, list, mirrorless, mount, pentax, pentax news, pentax rumors, pool, products, ricoh, ricoh japan, size, wonder
DA 18-55 WR replacement on K-3 II CharLac Pentax SLR Lens Discussion 19 04-19-2018 08:29 AM
Pentax K3ii officially discontinued dcpropilot Pentax News and Rumors 509 03-05-2018 09:25 AM
K3ii replacement 36mp? amp Pentax DSLR Discussion 35 02-21-2017 10:17 PM
Successor to K3ii - care to guess when? Spodeworld Pentax K-3 & K-3 II 178 11-12-2016 01:57 PM
Replacement K3ii also under affected serial Numbers khilla Ask B&H Photo! 2 07-23-2015 11:12 AM
All times are GMT -7. The time now is 03:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
