Originally posted by photoptimist 200 mA per card might be true for some cards, but the spec for the fastest UHS-II mode (HD312) permits card power consumption levels of up to 2.88 W (or 870 mA @ 3.3 V)
UHS II HD312 is the fastest, I can understand that it hits some limits of battery power. Here I was referring to the current write speed of the K1 when writing to the two SD cards, 200mA is a max spec for SD, that's why I don't think power is a limitation. With the K1 power budget as it is now,
K1 buffer clearance could be 4 times faster if subsequent images were written in the two SD cards simultaneously. I mean, when shooting a bust of images #1,2,3,4,5... image 1 would go to SD1, image 2 would go to SD2, image 3 would go to SD1, image 4 SD2, image 5 SD1. I can only imagine that the two SD card slots share the same bus, en eventually the same controller chip.
