Closed Thread
02-16-2018, 12:19 AM   #211
LightBug's Avatar
QuoteOriginally posted by Fenwoodian Quote
Kenspo, thank you for your prompt and candid answer!
If by adding 5-Axis In-Body Shake Reduction to pixel shift (like the rumors claim) the new K1 is able to shoot moving objects in the pixel shift mode (while handholding the camera) it would be revolutionary! This would be a unique pixel shift capability that only Pentax would have. Many photographers would be very excited about the new K1 camera if it could do that.
I assume you are joking? Obviously pixel shift cannot be applied to subjects that has any kind of movement.
02-16-2018, 12:44 AM   #212
In my view, RAW data should not be manipulated and I don't see the point in providing any new/changed processing of RAW data
3 reasons why I don't want raw data to be manipulated 1 is as time goes on we get better NR software 2 It is always better to customise the NR for different scenes, 3 I would sooner allocate processing power to something else.
---------- Post added 02-16-2018 at 01:57 AM ----------
What hardware was upgraded?
I have a feeling that the noise reduction that we see in the KP and the K70 had more to do with the sony sensor and Dual conversion gain, pentax may have optimized how they manage it with hardware but I feel its more to do with DCG
If pentax is saying that the k1mr2 has the same tech as the K70/KP we might be seeing a new 36mp sensor from sony that has DCG which is not out of the reason of possibility as sony is releasing several newer sensors with it, and not to mention I would think that 36mp is the new enter level sensor for base model FF camera so I could see them wanting to refresh that MP with DCG.
02-16-2018, 12:57 AM   #213
Supposedly, they added this:
(Also posted on the other thread)
02-16-2018, 01:42 AM   #214
redpit's Avatar
What I learn and hear is great news for me. I remain a loyal Pentaxian simply because I get the results i want from Pentax equipmnet and I don't see that changing any time soon!
In about a week we should know more, but I'm excited not only with the K-1MkII but also the Pentax rational that is aiming at Pentaxians satisfaction and favor and not just making money from selling new products.
Great times ahead for me.
02-16-2018, 01:50 AM   #215
robjmitchell's Avatar
The Accellerator chip being added seems to function by correcting noise at the pixel level rather than hiding noise by smearing the data. That’s why it can preserve dynamic range and detail, unlike noise reduction.
Its like comparing pixel based vs vector based drawing programs.
02-16-2018, 02:22 AM - 3 Likes   #216
I have no idea what the new "Pixel Shift Resolution (SR II)" is about
Looking at the alleged leaked specs, they say (with emphasis added):
Pixel Shift Resolution: Available, Motion Correction ON/OFF, Image Stabilization On
That seems to indicate that pixel shift would be able to be used with SR enabled (rather than PS forcing SR to be disabled as happens currently (at least with the older firmware that I'm using)). Hopefully it will make PS more practical for handheld use under certain conditions. It might be just firmware changes, so perhaps the K-1 might get this feature as well eventually.
02-16-2018, 03:03 AM   #217
clackers's Avatar
I can't see how it does anything other than bake RAW files, though (which I don't like).
Happy to be shown otherwise!
02-16-2018, 03:13 AM - 1 Like   #218
BigMackCam's Avatar
My initial reaction to baked RAW files is the same... but we mustn't forget that they're already baked to some extent. We've had members analyse RAW files from different Pentax cameras before, and it became quite clear that there was processing applied to those images shot above certain ISO levels. I'm sure other manufacturers do this too. So long as we're not losing any detail, dynamic range, colour accuracy and other important data as a result of (additional?) processing, I might actually be open-minded to it. Especially when I look at the quality of the KP's high ISO files...
02-16-2018, 03:13 AM - 1 Like   #219
None od us know for sure, but if I ware to guess how it does handle the noise, its that it contains sensor readout signal codec,on raw electric level that equalizes peaks in signal phase before it is hashed into data used by camera main cpu. That might be only one of its functions ofc.
02-16-2018, 04:00 AM - 3 Likes   #220
aurele's Avatar
QuoteOriginally posted by kenspo Quote
So much whining
it's sad really !
Keep shooting and enjoy the tools
02-16-2018, 04:34 AM - 2 Likes   #221
Sandy Hancock's Avatar
Without being too scientific, I have been really impressed with the high ISO output from the KP.
There's something different going on....
02-16-2018, 05:09 AM - 1 Like   #222
All noise reduction does is average out the data to make its smooth. Problem is you include the bad data with the good.
On the other hand if you add a correction/junking step where you look for outliers and substitute them with good data from the average of the pixels around it, then you remove the bad data contamination.
02-16-2018, 05:51 AM   #223
D1N0's Avatar
They are not simply smoothing over pixels with this noise reduction chip. Not like in smart phones.
02-16-2018, 06:01 AM - 1 Like   #224
All makers "bake" their raws to some extent. As long as it doesnt get in the way of what image results I get, I do not care. A raw is an intermediary file format to get to the real image result.
02-16-2018, 06:58 AM - 2 Likes   #225
What is your insider knowledge on this?
I read the original post
The Pentax K-1 Mark II camera will have PRIME IV 14-bit imaging processing chip with the original Accelerator Unit (a RICOH developed processing device) that effectively suppresses noise and reproduces fine-details with rich colors even at high ISO levels. The Accelerator Unit was first introduced in the Pentax K-70, followed by the Pentax KP and is now being introduced in the K-1 Mark II marking the 3rd generation.
Closed Thread
36mp, accelerator, camera, chip, conversion, dslr, ii, ii dslr camera, increase, iso, iso performance, k-1, k-70, k1, kp, mark, noise, pentax, pentax news, pentax rumors, people, performance, pm, post, sales, sensor, sony, specifications
Ricoh Theta SC camera specifications leaked online(No 4K) OoKU Pentax News and Rumors 20 10-23-2016 11:45 AM
Pentax K-70 Specifications Leaked PF Staff Homepage & Official Pentax News 0 06-07-2016 03:31 AM
Pentax K3 ii vs Canon 5D mark ii mogge Welcomes and Introductions 49 03-27-2016 02:39 AM
Pentax KS-1 Specifications Leaked Adam Homepage & Official Pentax News 0 08-21-2014 11:16 PM
All times are GMT -7. The time now is 01:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
