Originally posted by Kingman With the K-1 to K-1 Mark II upgrade, is Ricoh offering a warranty period for the newly installed components. Will Ricoh install the latest firmware into the upgraded K-1 Mk II body? Has Ricoh stated anything about replacing the seals for the body?
I don't think we've seen any warranty info. That's apt to be interesting given the range of potential purchase dates. You'd think at least a 90 day warranty if out of warranty at the time the upgrade is performed, but I throw that out there as just a standard length of time I've seen when repairing electronics. Perhaps it will be something along the lines of a minimum of 90 days, e.g. you if still have 6 months, your original warranty is in effect. If you are out of warranty, here's 90 days, only 55 days left, then a 35 day extension . That's my best guess.
Regarding things like seals, I would think it goes without saying that any seal broken to perform the upgrade would be replaced. Ricoh isn't going to go break people's weatherproofing over what is probably mere cents worth of o-rings as part of a $550 upgrade.
