Originally posted by ecostigny Thanks for the helpful response. I figured you weren't relying solely on ambient light and was curious as to your lighting solution.
Yeah, shooting greater than lifesize macro without a flash would be quite a challenge...
Originally posted by Thagomizer Thanks for the set-up image. That's a bit more advanced than my standard Pringles tin diffuser! What bracket are you using?
It's just an old vintage L-braket. Photo of the "doodads" below.
Note that I'm triggering the flash from a Yongnuo wireless trigger, but it's not wireless triggering! The trigger just happens to have a PC-sync port with screw threads. I tried using the one on the K-3 body directly, but that doesn't have the same size of threads, so I couldn't screw the cable in place, and it kept unplugging itself at inopportune moments. The most important item is the bracket to get the flash horizontal. I got it on Ebay and I think it was meant for video lights, but the nice thing about it is it can't move left to right. Some people use small ballheads to achieve the same thing, but if your flash is heavy (and mine is), this solution is much sturdier. I'm not finding it on Ebay at the moment though...
Originally posted by danecs Lunch time unboxing, I'm really impressed with how solid the lens feels. Finishing looks really good as well.
Now if I was smart I'd have a body with me.
I agree. Aside from the hood, there's not much to criticize in the build quality. Coming from the D-FA WR, I do find that there's not much area to grab onto that is neither the focus nor the aperture ring. Thankfully, the focus action is very well damped, so you're unlikely to change your shot's magnification inadvertently while approaching the critter.
Oh, and since the actual front element recesses deeply into the outer barrel - which may allow both dust and even inquisitive small critters in - IMHO you should consider the included UV filter as a replaceable front element and always leave it on.
