Personally, I find the working distance is too great with a very long lens. It requires much more flash power and it's often hard to find an appropriate point to brace on while shooting so far from the critter. My poor man's long macro is a Tamron Adaptall 90mm (52BB) coupled with the well-regarded Adaptall 2X tele-converter, which gives a 1:1 180mm lens. I've gotten good results using this with a Raynox DCR-250 for high-magnification shots (e.g.
here), but frankly it no longer sees much use. For me 90-105mm really is a nice sweetspot for in-situ nature macro of critters roughly 5 to 30mm in size.
To come back to the Laowa, they claim it's an internal focus design, but the front element recedes deeply into the lens at infinity and progressively extends as you focus closer and closer. To me this behavior is very similar to a more traditional macro design (like the D-FA 100mm WR), only with a fixed-length external barrel that goes all the way to the maximum extension of the internal barrel (rather than only extending to the infinity focus point as the external barrel on the D-FA 100mm WR does). Not sure if that description is clear...
Nevertheless, what I didn't expect is that having this fixed length external barrel is actually super useful. It makes it much easier to setup a diffusion surface since you know that the barrel will always be there and is a solid point on which to rest a diffusion surface. With the D-FA 100mm, you always have to worry about the lens extension/retraction - both in trying to avoid putting to much pressure on the internal barrel when fully extended, and at the other end not having anything there (to stop your diffusion surface from sagging into the field of view) when the lens is retracted. To me this difference is an unexpected but very welcome improvement in shooting with the Laowa versus D-FA 100mm plus Raynox DCR-250 (in the 1:1 to 2:1 macro range).
