Originally posted by Rondec I think the solenoid issue was particularly problematic because they didn't really have a fix. As far as I can tell, they simply replaced bad solenoids with the same solenoids that were prone to failure.
They did not know and actually could not know what the problem was for quite a long time.
For quite a while it was said that the complete "diaphragm control unit" was replaced.
But because this is hours of work even for the very experienced I wouldn't be surprised if actually they just exchanged the body ...except the bottom plate with the serial. Thats how often it was handled with the even more expensive K5 during those sensor stain problems.
Changing the body was cheaper than replacing the sensor plus new alignement. So my guess is that it was similar with the K30/50.
I have undertaken replacement of the complete aperture block assembly once and will never ever do it, it is hell of work.
It was much later on that Ricoh found out
(through us that is, i.e. here in this forum!) that there is a much easier solution, that it's only this tiny solenoid and replacing it is going to be done within lets say 30min if your workshop is ready for work.
Originally posted by Rondec The fact that this was occuring outside of the warranty period combined with that fact made them unlikely to do anything about it. That said, many fixed their own cameras (better than Pentax would have) or got someone else to do it for them.
In the European Union warranty is 2 years and often people got their bodies repaired if damage happended a few month outside of this warranty period. Later one could ask for a special price and still got it cheap, something like $150.
But it was just the same critical solenoid which was replaced... with the same one! So often the problem occured again.
Step by step they worked on modifying it but this started late around Dec. 2015 and as I have showed in my
research , there was finally a step forward.
Nevertheless: The DIY solution with the old "made in Japan" solenoid is and was always the best solution but only available to DIYers because this solenoid wasn't produced anymore. Very few NOS (New Old Stock) solenoids were available for a short time in Japan but not anymore. So finding solenoids from DSLR bodies (*ist D up to K-r plus Samsung equivalents) or buying it on ebay is right now the only possibility.
Originally posted by totsmuyco I think if Pentax would've known that this aperture block would happened, they would've looked for another manufacturer. It's definitely a bad problem I wouldn't want to have after the warranty period. It pushed me away from getting a ks2.
There was no other manufacturer. Shinmei Japan produced it in SLR days and moved production to China. They sold solenoids to other manufactures and there are a few companies who produce similar solenoids but not the same (and they for sure are worse, I have tried and tested them).
The problem was that once machines were out of Japan, that was it!
The
idea/patent of the solenoid was very good. When the manufacturer Shinmei moved production to China, the first green bodied made in China solenoids were tested for a longer time just in the flash circuitry of: K100D (year 2006!), K110D, K200D, K-m, K-x and K-r. None ever failed so they finally started to use it in for aperture control in the K30. This was in 2012, so up to 6 years without failure. It wasn't to be expected that the very same solenoid which worked alright in the flash ciruitry for 6 years would produce such difficulties in the aperture/diaphragm block.
And then fault-finding was difficult as I described already. It was at the end of the production of the K-50, K-S1 and K-S2 were already produced, first ones out on the market. But then they moved, there are hardly any K-S1 and K-S2 with this fault... they would have shown up by now.
It is pretty easy to check the date of manufacture using our
Check Camera Shutter Cound @Manufacture Date link: All K-50, K-S1 and K-S2 built from Dec. 2015 onwards should be safe.
And I wouldn't worry about the K-70 at all.
