I am not planning to acquire the D FA* 50/1.4, so I'm not affected directly by DPReview's treatment of the lens. However, I go to that site occasionally, and was interested to hear what they say about the lens.
To its credit, the piece covers a number of important aspects and presents positive and negative comments, and the authors have responded to numerous comments from readers. However, I find the review to be largely subjective and absent of some key details. Furthermore, it's easy to spot snide shots against Pentax.
- The review mentions that the tactile pattern on the focus ring is "not quite as comfortable as the ribbed design common to many other lenses." No other specific lenses are indicated, and the review doesn't explain how the author finds the ring less comfortable. It's not apparent whether the 'comfort' factor was specific to one person's preference or was a general conclusion of several testers. (Edit: At DPR, one commentator has remarked that the focus ring offers excellent purchase for gloved fingers while wet or icy. It's unlikely that the DPR review tested the lens under various environmental conditions.)
- The review emphasizes the weight of the lens, but inconsistently and absent of any comparison standard. To put the weight "into perspective," a comparison is made only to the combined weight of two unrelated Canon lenses, which are not mentioned elsewhere in the review. The Pentax is called a "fairly weighty lens" and "heavy and bulky, even by modern 50mm F1.4 lens standards." On the contrary, another statement concludes that "the [lens] is one of a generation of heavy, expensive standard prime lenses...".
- Concerning the focusing action, the review states that focusing is "not quite as discreet as some other modern optics." None of the others are named, nor is it clear whether the focusing noise is really a problem in real-world use. The review should have explained the criteria or standard; an objective test would have included sound intensity measurements.
- A concluding positive point says that the lens has a "superb build", but the review provides no discussion or evidence to support that conclusion. It's not clear what DPReview uses as criteria to assess the build quality of a lens, nor is it apparent that the reviewers have any credentials to do such an assessment.
A couple of points seem to be
shots at Pentax. In one paragraph, the review attempts to draw a similarity between the Pentax lens and the Tokina Opera 50/1.4. It's not obvious why this comparison is necessary, and it seems to be a speculation, perhaps aimed at implicitly questioning the inherent quality of the Pentax lens.
In my opinion, the last sentence of the review is another shot that's neither pertinent to the review nor realistic: "For many reasons -- not least, let's be honest, the paucity of options for full-frame Pentax photographers -- the FA* 50mm F1.4 should be on every Pentaxian's wishlist."
On the positive side, the review does present several points that a prospective buyer should research further by using the DPR review as a cue to potential issues. For example, the weight of the lens might be a factor, so one could decide whether 910 g is too heavy for them. Compared to a 500mm f/4 lens, the Pentax lens is lightweight; compared to a FA 43mm Limited, it's a monster!
- Craig
