Originally posted by reh321 You still haven't answered my two questions:
(1) Do XQD interfaces have "pins", like the old Compact Flash units did?
(2) What, other than 'prestige' would be gained by putting XQD units in Pentax cameras??
1,
no they dont.
2,
security,
speed,
reliability.
@ogl : there is no such thing as a CF card. there is: CFExpress, CFast, CFast 2.0.
One really has to differ between those, because of the different standards, and for the "CFExpress"(which is something completely else compared to a CFast) you should see that its more like a better XQD card which is also compatible to the XQD-standard.
(What means that: A device capable of r/w CFExpress will be able to r/w XQD. But a mere XQD slot, will have a hard time reading CFExpress. Nonetheless, i think it will be very much like VHS(XQD) vs Betamax(CFExpress)... XQD will win in the end and already has defined a V2.0 Standard, which makes it equally capable as the CFExpress. But looking that far. IMHO may really be a bit too far.)
Quote: again:
no there are no pins on XQD/CFExpress cards or its reading devices. none.
it has 3 separeted "contact surfaces" separated by a much stronger and thicker material then the "ribs" on an SD card(which are very likely to fall off one day and at some point in time may kill your SD-slot by the way)
Those 3 contact surfaces sit securely in a very rugged case, protected by the hull of the card which protrudes OVER those contacts so they are protected.
Admitted: My desire maybe could be considered as setting unnecessary goals too high, because first Autofocus and burst speed should see major improvements...
BUT: even if we see "ONLY" UHS-II SD-cards in the upcoming gear,... honestly i will be also satisfied since Sony shortly introduced its new "TOUGH" SD-cards.
Only plz consider this:
If you say, you are OK with SD and pentax is slow and you are willing to live with it,
no one will build even UHS-II dual SD-slots into your next PENTAX camera .. no one.
You will get again: 1 slot (because you already bought a KP or at least most likely said, "hey its the bees knees") with UHS-I bus... and slow shooting rates. which in the end may be OK for you but it would be bad for the brand and the system as a whole because we would loose more and more customers, to other brands.
@reh321:
As I see you have lot of reputation on the forum and are a long time member, i am begging you on my knees to consider what i wrote here,
I think you have a lot of responsibility when you spread words about such important issues.
Nonetheless:
I am totally convinced, that as a loyal customer, one has a right to demand improvement from the company he bought so much gear from and fed it with several thousands, and more several-thousands of dollars.
again: a Dual-Multi Slot design, should mean no problem to all the SD-card lovers... i really dont understand why you wanna go against a compromise and say only your point of view is the truth.
