Originally posted by sculptor666 extension tubes with contacts are few and far between (pentax has never made any). the ones that do exist do not do well on FF, especially if you stack them beyond 50mm or so... you get different results with different lenses though. tubes on a 150mm don't do nearly as much as they do on a 50mm. user review says that this lens won't work on pentax ext tubes (technically it will, but only at f2.8... which is as good as not working at all) and that it won't work with the 1.7x t/c... maybe there's a conflict with the lens elements touching each other or something.
Thanks for the reply, I'm just wondering if the ext tubes that were tried had contacts, as the contacts would have to be in the same place anyway. Contactless tubes and bellows would behave the same way, resulting in shooting wide open.
