Originally posted by beholder3 For a mere 3,5cm more working distance loose all AF for normal portrait work and lug around a full pound more weight and use 77mm filters instead of 49mm?
That sounds like a very debatable trade-off.
Assuming the figures are accurate, in practice the difference is not so small, because in practice 1:1 is not reached most of the times.
Anybody who has used in the field a 50mm and a 100mm has found that it makes a whole lot of difference.
From 100mm to 180mm it is almost the same. A 150mm offers a little less advantage, but still welcomed.
Few pictures are actually shot freehand at 1:1 in the field.
If a bulky tripod comes into play, then a bigger lens doesn't make a whole lot of difference, isn't it?
At high magnification the DOF is very thin, and to get some more the only option is stopping down.
A pity that traditional lenses suffer a lot from diffraction.
Professionals always use stacking if possible.
It is complicated in studio, in the field it's a nightmare.
This is why modern macro lenses stretch the optical limits a lot using floating elements.
The Laowa lens I mentioned does nor suffer too badly from diffraction even at the "real" aperture of f/128.
Let's not forget that at 1:1 f/11 becomes f/32.
To get the best performance with very high reproduction rate a serious macro photographer shoots wide open a lot of pictures and then stacks them.
Some old school micro lenses don't even have a diaphragm.
150mm and 180mm macro lenses are not made for this use. They are made for macro hunting, shooting subjects that rarely require more than 1:2.
Modern floating designs have and edge also in this case, each cm of distance you gain allows for better chances to picture the subject before it flies/runs away.
Compared to older designs, floating elements allow for more freedom. If it's important or not is left to our own judgement. What we shoot and how.
What I know for sure is that short focal optics (for higher magnifications) use the same tricks to gain a couple of cm, which are badly needed to avoid shading the subject with the front of the lens.
At home I still have a micrometric rail (Manfrotto), a microscope stage, a microscope ring light, micro objectives, etc, etc... well, even with some good equipment and lots of ingenuity it's NOT easy.
These chinese are doing a great job making it simpler, and more affordable. Both in the field and in studio.
---------- Post added 24-09-18 at 05:09 PM ----------
Originally posted by beholder3 You are aware that Laowa has at least one PKA lens?
Just got their reply.
They say they don't.
It seems that sooner or later they will
---------- Post added 24-09-18 at 05:18 PM ----------
Originally posted by Mistral75 A working distance of 165mm for the Irix Dragonfly 150mm f/2.8 Macro 1:1 versus 129mm for the smc Pentax-D FA 100mm f/2.8 Macro WR is not 'the theory', it's according to specifications and/or measurements.
Sorry, I thought it was a figure derived from the MFD of Pentax, getting the Irix likely spec in a "theoretical" way.
I thought that the specs of the Irix were still not available.
My bad, I presumed a bit too much. I had a look a couple of days ago and no such data was available.
EDIT:
I wrote this post with the impressive Laowa macro achievements in mind.
It seems that Irix is a little behind under this point of view.
If the quotes are from the front of the lens, I would expect a little better from a modern macro lens with floating elements.
Maybe this was not the goal, maybe it shines in other ways... but under this point of view it could have done better, considering that the D FA 100mm uses the same old fashioned helicoid used by all other past Pentax macros.
A few more cm are useful, but it's hardly a miracle, considering the difference of focal. I would have expected more.
I wrote my post considering the 3.5cm difference only "theoretical", and I took for granted that in reality it should match Laowa's impressive achievements, especially considering how well Irix has done with their wide angles... I just hope the new lens will show other optical qualities.
I guess it's very likely to happen.
Whatever it is, I'm glad we have one more tele prime with 1:1 reproduction ratio that can work with P-TTL flashes.
Laowa's macro lenses, as impressive as they are, can't be used in P-TTL mode. It's a huge shortcoming for macro hunting.
