Show Printable Version 538 Likes Search this Thread
01-27-2019, 11:08 AM   #46
The Nikon 70-200/4 (which came to the market at 1400 EUR btw) weighs 0,85 kg.
The Pentax DA* 50-135, which (1000 EUR) is fully equivalent to a 70-200/4, weighs 0,68 kg.
The old Tamron 70-200/2.8 for Pentax (608 EUR) weighs just 1,15 kg, but it is a full stop faster.
01-27-2019, 12:37 PM   #47
QuoteOriginally posted by beholder3 Quote
For landscape as light weight alternative to the DFA*70-200 2.8, it wouldn't need to be f4 constant. If it was a DFA 70-200 f4:5.6 WR , would be fine for me. Like the DFA28-105. Originally I had the 24-70 2.8, then I also got the 28-105 but had shutter shock issues with the K1, now with the K1 II this little DFA28-105 is perfect: small, sharp, quick to focus and filter thread 62mm is great I can even use the filters I used for apsc. If the DFA70-200 f4 has a 77mm filter thread it will be perfect, 82mm is the very limit for 100mm filter systems. The DFA24-70 has a 82mm filter thread and I had to reverse and modify my Cokin filter older to avoid vignetting, same issue with the Haida 100mm system, only one filter can be used without vignetting, stacking 2 filters creates vignetting with the DFA24-70... but not with the DFA28-105.
Just looking at the FA lenses:
-> FA 100-300 f4.5:5.6 weight 605gr. Filter diameter 58mm
-> FA 80-320 f4.5:5.6 weight 550gr. Filter diameter 58mm
-> FA 70-200 f4:5.6 weight 465gr. Filter diameter 49mm !
The DFA28-105 weights 440gr.
You can carry 2 of those in a backpack, even for hiking (I've carried the DFA150-450 at altitude 3000m to photograph alpine ibex, it was good fitness :-) ).
01-27-2019, 01:03 PM - 3 Likes   #48
Let's get a bit more up to date, as Pentax won't work at the same standards as in the past:
Canon 70-300 f/4-5.6 - 710g, 67mm filters
Nikon 70-300 f/4.5-5.6 - 680g, 67mm filters
Sony 70-300 f/4.5-5.6 - 845g, 72mm filters
I'm afraid to look at Sigma, I'm sure they must have a 70-300 f/1.4 weighting 10kg
Don't we all know the lens roadmap? Pentax has two lenses in this range planned: the D FA 70-200 f/4, and a 70-300-ish telephoto zoom.
01-28-2019, 05:18 AM - 1 Like   #49
Strange. Why would there be both 70-200 f4 and 70-300, too much overlap to my taste. Since there is already the excellent 70-200 f2.8, I would rather see a light weight alternative optimized for size/ weight rather than a 800 gr f4 lens. What does the roadmap says? Should that be asked again to Ricoh at CP+?
JAre
01-28-2019, 07:33 AM - 1 Like   #50
Keep that question for Adam's interview with Ricoh Imaging; it's a good one, to know how far will they go in completing the D FA lens line. But I can think of a possible reason: the 70-200 f/4 would work well with a rear converter.
The roadmap will be updated for CP+, sure; and it's not meant to be precise (or a binding contract, if you want). But I expect only the very next lenses to have the basic specs (i.e. focal range and max aperture)... I doubt we'll find out much about the 70-300-ish zoom.
By the way, I'm surprised at the lack of solid rumors/leaks.
01-28-2019, 07:51 AM - 1 Like   #51
I agree. When the 70-300 comes out, the Pentax DFA line-up will have four telephoto zooms, two standard zooms, and one wide-angle zoom. And here I was under the impression that one of the great advantages of FF was on the wide angle side of things. Hard to believe that by how this DFA line-up is shaping up. Even the prime line-up is tilted toward the normal and telephoto side of things, with nothing wide than 31mm.
This is not to suggest that a DFA 70-200 f4 won't be a great addition to the line-up. I just have questions as to whether it should have been given priority to a slow aperture 70-300 and a slow aperture wide angle zoom. The size, weight and cost of the current wide angle and telephoto zooms in the DFA line-up has forced quite a few K-1 users to rely on inferior legacy glass.
01-28-2019, 08:14 AM - 1 Like   #52
I've had TC, sold them, buy TC again and sold again. Image comparison of crop vs TC told me that TC is only valuable when the sensor resolution doesn't allow to crop, e.g 24Mpixel instead of 36Mp or 45Mp. AF generally works better without TC, so unless the lens out-resolve the sensor by a good margin TC don't bring anything (get the image on the whole frame and bump iso to compensate for loss of light => no better than cropping of high res. sensor). So, unless Pentax makes a fast 16Mp or 24Mp camera, I'll never get any TC again. TC is great with a 16Mp full frame that boast 10 frames per seconds, OTOH TC on a K1 is a waste.
01-28-2019, 08:15 AM - 1 Like   #53
Mistral75's Avatar
When you see that Ricoh themselves say that the Ricoh GR III that people will be able to touch and try at CP+ will be a prototype under development...
01-28-2019, 08:39 AM   #54
Banned
Maybe CP+ is all about GRIII and nothing else.....
01-28-2019, 08:45 AM   #55
QuoteOriginally posted by Mistral75 Quote
Nonsense.
01-28-2019, 09:00 AM - 1 Like   #56
Well, that's not true. I was in Japan in November last year, and I tried a GRIII in my own hands, so, I can tell you that the GRIII is real and it works. But I'll really curious why things happen behind the closed door of Japan, and to me who could get a sense of various tonalities of the Japanese culture (from the traditional Japan post WWII to the new generation of teenage junkies), it's amazing that Ricoh Imaging are being so back anchored in the traditional Japanese model and so cut out from the rest of the world. I find this both fascinating, and also frustrating: fascinating because traditional Japanese culture is fascinating for me ; frustrating because it could be that Ricoh Imaging takes development directions based on Japan and that those choices may not make sense for me anymore in the future.
01-28-2019, 09:02 AM   #57
Mistral75's Avatar
Nonsense.
Really? Still they do. You who believe in Ricoh Imaging's words and in their words only, the following is what they published on 15 January:
QuoteOriginally posted by Ricoh Imaging:
新型GR タッチ&トライ
開発中の新型GR(試作機)のタッチ&トライコーナーをご用意。進化した「GR」をどこよりも早くご体験いただけます。
Translation:
New GR Touch & Try
There will be a corner to touch and try the new GR (prototype) under development. You will be able to experience the evolved 'GR' earlier than anywhere else.
Source: CP+2019出展案内│RICOH IMAGING
Well, that's BS. (...)
See above.
01-28-2019, 09:21 AM   #58
See above.
They aren't going to write released when it's not. There will be an official press release dedicated to the GRIII and that's the way things work for every company out there.
01-28-2019, 09:39 AM - 1 Like   #59
Mistral75's Avatar
They couldn't write 'released', I agree. But they didn't need to. Nor did they need to use two expressions to emphasise the same thing, 試作機 (prototype) and 開発 (under development). They could have simply written
中の新型GRのタッチ&トライコーナーをご用意。進化した「GR」をどこよりも早くご体験いただけます。
(There will be a corner to touch & try the new GR. You will be able to experience the evolved 'GR' earlier than anywhere else.)
However, they chose not to do so.
01-28-2019, 10:05 AM   #60
ogl
Banned
Translation:
New GR Touch & Try
It means that GRIII is still under development and it won't be launched after CP+2019? Maybe close to summer?
35mm, apertures, aps-c, camera, d-fa, dslr, edges, f2.8, f4, ff, field, hd, iq, length, lens, lenses, limit, page, pentax news, pentax rumors, question, range, ricoh, sensor, star, telephoto, terms, view
For Sale - Sold: K10D+grip, DA12-24mm,14mm 2.8, 75-200 f3.8, 28-200, 70-300, 80-200 f4.7-5.6 igowerf Sold Items 2 02-07-2018 08:33 PM
Lens tests on K-1 : 15-30, 24-70, 70-200, 31, 43, 77, 100 Macro, 28-70 and 80-200 Mistral75 Pentax SLR Lens Discussion 14 06-28-2016 11:46 AM
How does the new Pentax 70-200 compare to Tamron or sigma 70-200? Sandi in Halifax Pentax SLR Lens Discussion 27 04-28-2016 06:25 AM
For Sale - Sold: Pentax FA 100-300, FA 70-200, M 28mm; Sigma EX 28-70, Apo 70-300; Tamron Di LD 70-300 stillnk Sold Items 17 04-08-2012 11:39 AM
Old sigma 70-200 vs New hsm 70-200 41ants Pentax SLR Lens Discussion 3 07-14-2010 06:38 AM
All times are GMT -7. The time now is 03:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
