Originally posted by stevebrot I agree that FF will become the standard for "serious" cameras, probably within the next 18 months and that the entry point will be in the $1200 range.
I guess that leaves Pentax keeping company with the low-end toys. (No offense intended to buyers in that price bracket, I do truly appreciate the current bang-for-the-buck of the current Pentax line.)
Now you have ask, why the move to FF for the "serious" cameras? The answer is easy...better performance match to existing optical technology. Just take a look at any recent lens review for FF lenses at dpreview.com. They test these both for APS-C and FF. The FF results generally blow the APS-C results away. The reason? You need more than just higher pixel density on the detector to produce results equivalent to even 35mm film. You need lenses capable of resolving to the APS-C format that are relatively free of aberration and distortion. Resolving to the APS-C format means resolution 1.5 times the historical standard set for film.
Good as the current crop of cropped-sensor lenses are, they really are no competition with what you can do on film with FF glass of similar quality and design. This is particularly true at the wide-angle end of the spectrum. With the development of high-resolution FF and larger sensors, the APS-C format may truly become somewhat of a dead-end except to support smaller lighter cameras.
Before everyone starts picking up rocks to hurl...
I would not be speaking so strongly except that I took some time this week to take a good look at a 11x14 black and white print that I made in the mid-1980's. The print was made from a 35mm Kodak Technical Pan negative on a LPL medium format enlarger sporting a Schneider Componon-S. The taking lens was a Tamron Adaptall-2 28/2.5, the exact same lens as is listed in my signature.
Now, I can take a loupe and scan that print and see extreme detail in the wooden door and rusted hardware of the subject (an old barn door). (I guess that is the old school equivalent to pixel peeping.) There is NO WAY that lens will provide an equivalent level of performance on my K10D. I know that for sure, I have tried!
So, why did I choose that particular print for comparison? It is because of the Technical Pan negative. The film is widely acknowledged to have had the ability to out-resolve the best optics that were put in front of it due to its virtually grainless thin emulsion. (Very, very difficult to use a grain focusing aid with, BTW.) There truly is nothing that compares in the current crop of consumer digital detectors or film, for that matter.
So, we have a middling lens, superb capture medium, and really, really good results. What, I now ask, would have been my results if I had cropped the subject to a 1.5 factor? I would have 2/3rds the detail based solely on the resolution of the lens. Simply put.
Now to muddy the waters further, what if I were to attempt the same shot today (the barn is still there) with my K10D? I would not be able to do it with my Tamron 28/2.5. Instead I would have to use a 18mm ultra-wide costing 2-3 times the inflation-adjusted price of the Tamron. It will likely not offer the low-distortion, rectilinear view of the Tamron, nor will it likely offer the center to edge sharpness. Do I need to mention the image degradation due to CA that characterizes this class of lens?
Now, that is the end of my rant. I could say quite a bit more, but the central issue of image quality remains.
Excellent post. I have to agree on this with you, if you want same wide angle for APS-C as for FF you have to pay more and resolution is worse. Excellent 31mm or 43mm become much longer with worse resolution on APS-C.
It simply is much more difficult to make excellent APS-C lens than FF lens, you have to correct result a lot to remove CA and distortion and you lose this soul of the lens like 31mm, 43mm lenses ... Which of new lenses is same quality ? Answer: None.
If Pentax decides to ignore FF market I might change brand next few years for brand which will offer under $1700 FF body.
The only way to stay with Pentax is if Pentax pulls gem of DSLR, something really marvellous and working 100%. I mean quick focusing, high iso , more FPS and legendary Pentax ergonomy (which they have already)
That's my opinion.
