Originally posted by JPT If Ricoh engineers are so Tokyo-centric, how come most of their cameras are marketed as “field cameras”, and how come Pentax cameras have such a following among landscape photographers?
The reason of my comment is that I am not sure if Ricoh Imaging will follow the Pentax path. I use a Pentax K1, I like it, but there are a number of things that could be better on how the camera operates and missing user programmable features. My point is, if Ricoh Imaging are small and have not enough resources to make complete new products, why don't they just deliver a firmware update that add great features to existing hardware. Typically, Pentax cameras have had SR for years, but the cameras don't take advantage of it (shutter speed computation is the same regardless if SR enabled or diabled), and there is no good work around things such as shutter shock beside noise reduction on the K1 II that mask out shutter shock effects, e.g. why not implement EFCS delay for OVF shooting? How much would that cost? Not much. On the K1, there are a number of software things that let me perplex, such as mirror going up and down when pressing the INFO button in LV mode to enable or disable ES (looks like implementation was an afterthought), why can't I enable of disable ES while LV keeps running?
Originally posted by JPT By the way, Nikon are based in Tokyo, too.
Yes, that's why user find so weird interfaces behaviour such as for instance when you use the joystick to move the cursor in the frame of the Nikon to focus on an are and push the joystick, instead of validation of the cursor position the camera get out of the mode, that's works in the lab for the team who wrote the firmware and tested it, but clearly that software behavior doesn't make sense for a photographer using the camera. I feel like the older engineering staff are being replaced by young staff who have no interest in photography and don't have interest in how camera are used by people who have no interest in software development. So that's a problem for all camera companies, so that's where Ricoh Imaging could make a bigger difference without needing lot of resources, but they don't seem to do so either.
