02-10-2019, 12:55 AM - 3 Likes   #1
HD Pentax-DA★ 11-18mm f/2.8 - some local indoors pre-series test shots
A German dealer just had a pre-series HD Pentax-DA★ 11-18mm f/2.8 on the small local photo fair "Mundologia".
One forist grabbed to opportunity to shoot some sample shots. Obviously indoors is not anywhere near a good scenario for this lens, but it is as it is.
Here are the shots:
The lens: http://h2097500.stratoserver.net/forumimages/2019/6568/6568_2019020929_k12003-2.jpg
18mm at F2.8 on uncropped FF: http://h2097500.stratoserver.net/forumimages/2019/6568/6568_2019020941_k11989-2.jpg
11mm at F3.2 on uncropped FF: http://h2097500.stratoserver.net/forumimages/2019/6568/6568_2019020926_k11995-2.jpg
11mm at F2.8 on APSC: http://h2097500.stratoserver.net/forumimages/2019/6568/6568_2019020956_k11985-2.jpg
The full thread is here: HD Pentax-DA? 11-18mm f/2.8 - erste eigene Bilder ? Pentaxians (needs log-in)
02-10-2019, 01:26 AM   #2
What is surprising, that FF 18 mm shot looks quite okay! Wonder how wide you get untill there is something like @11 mm FF shot.. that did surprise me.
02-10-2019, 02:19 AM   #3
Good to see the test shots coming! Judging from the other examples 11-18 and revamped 35mm F2 on january 31? - Page 63 - PentaxForums.com
it looks like Pentax perhaps made the image circle at 11mm a bit to small again (da15). To early to tell but there's a sharp decline in resolution at the edge of the frame.
Looking forward to more test shots!
02-10-2019, 02:27 AM   #4
swanlefitte's Avatar
The walls would curve way worse with my sigma 10-20.
02-10-2019, 02:34 AM - 2 Likes   #5
Sandy Hancock's Avatar
QuoteOriginally posted by house Quote
It looks like Pentax perhaps made the image circle at 11mm a bit to small again (da15). To early to tell but there's a sharp decline in resolution at the edge of the frame.
Yes, way too early. I would suggest that "sharp decline in resolution" is indistinguishable from normal depth of field as the subject retreats from the focal plane.
02-10-2019, 02:44 AM   #6
ffking's Avatar
Yes - agreed - the shot appears to be focused on the backpacks, and there is nothing of comparable distance from the focal plane near the edges of the frame
02-10-2019, 04:20 AM   #7
MMVIII's Avatar
I have not seen anything which might support such a statement. And I highly doubt it. Vignetting at K1(!) at 18mm seems very low. The 15mm is built for compactness, even if there might be some vignetting wide open at the widest angle, at 15mm f4 I'm pretty sure it is in another league. But, let's wait for real user experience accompanied by some formal tests?
02-10-2019, 04:36 AM   #8
To jump the gun the best image to check is the 11mm f3.2 on ff. Yet even then there is the image circle and circle of good definition. Is the 11mm on apsc using the whole image circle or is the circle of good definition used smaller?
02-10-2019, 05:04 AM   #9
QuoteOriginally posted by swanlefitte Quote
Yellow outline is APS-C...
Edit - Image removed as was wrong - see post on page 2.
02-10-2019, 05:18 AM   #10
QuoteOriginally posted by phoebus Quote
Your aps-c frame looks a bit too big...
02-10-2019, 05:29 AM   #11
Now it appears the image circle isn't centered. More vignetting in the right corners.
02-10-2019, 06:07 AM   #12
retired sw engineer
reh321's Avatar
QuoteOriginally posted by beholder3 Quote
Here are the shots:
The APS variants look very rectilinear - much better than my Sigma 10-20. Did the article say anything about 'correction'?
02-10-2019, 06:19 AM   #13
QuoteOriginally posted by taktoon Quote
What size would you like??
02-10-2019, 06:28 AM   #14
That's just shake reduction at work.
02-10-2019, 06:37 AM   #15
APS-C size (Pentax APS-C size). Your crop looks generous in height. KP sensor is 23.5 x15,6 and your crop looks more like 24 (which is fine) x 18 (which is a lot). And you get 4/3 ratio to my eye
11-18mm f/2.8, 11mm, da* 11-18mm f2.8, f/2.8, hd, hd pentax-da★ 11-18mm, indoors, indoors pre-series test, lens, pentax, pentax news, pentax rumors, shots
HD PENTAX-DA★11-18mm F2.8ED DC AW ramseybuckeye Pentax SLR Lens Discussion 47 02-06-2019 10:16 AM
Photo Life News letter - HD PENTAX-DA★11-18mmF2.8ED DC AW and the HD PENTAX-FA35mmF2 jpzk Photographic Industry and Professionals 4 02-04-2019 08:15 AM
HD Pentax-DA★ 11-18mm f/2.8 Mistral75 Pentax News and Rumors 474 11-01-2017 09:07 AM
Happy 11.11.11 11:11:11 m8o General Talk 10 11-12-2011 08:17 PM
★★NOW IN STOCK★★Pentax K-5 Limited Edition★★ Chuck-B&H Ask B&H Photo! 11 03-31-2011 05:29 AM
All times are GMT -7. The time now is 09:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
