Originally posted by Rico That's the point RonHendriks1966 if the GRIII had UHS-II you wouldn't need to hang a power pack with an SSD on your GRIII.
The GR is a do it all compact single focus video and still street camera. It just doesn't deliver 4k video due to the UHS-I bus. At least they finally gave us 14-bit RAW stills.
I think for that it needs a little more then just a faster bus. It needs a bigger battery pack. It needs a faster processor. It needs something to dissipate the heat building up. A different sensor then it now has. So that would make it a very different camera, not fitting in the small size it now has.
---------- Post added 23-02-19 at 19:26 ----------
Originally posted by biz-engineer how about adding two micro XQD card slots for speed and data redundancy?
How about loosing those card slots and put 64gb/128gb memory inside the camera?
The G900 has 6,5gb memory inside. I hope someone cracks it open. I think you will find a micro-SD card inside.
