Originally posted by MrNPhoto The original limited lenses are full-frame and quite compact for what they deliver (esp. the 43mm). No reason why new FF limiteds can't also be compact. They aren't star lenses, and can be offered at apertures that allow more compact designs.
I don't think you will see them as compact as the film era lenses. The film era lenses had screw drive AF motors in the body, so there was no AF motor in the lens and those early screw drive AF lenses were basically manual focus lenses with some minor modification. The resolution of film and the AF accuracy of early cameras was both seriously lacking compared to modern digital sensors and AF. The Sony A9 checks and adjusts AF 60 times per-second and that is not something old screw driven could keep up with. AF lenses from just 5 years ago can't keep up with that. The need for higher resolution glass with more correction will make the lenses larger, but the need to have fast accurate AF is what will really make the lenses larger. Unless Ricoh releases manual focus Limited glass, they will be larger.
I would love to see a manufacturer release a mirrorless body that didn't even have AF and a line of modern manual focus lenses like the Zeiss Loxia and the Voightlander 50mm F/2 APO..... One not made by Leica.
