Originally posted by Rico Why would a DFA35 ƒ2 AW have to render and be like the DFA*50/1.4?
Because if it didn't, folks would talk about nostalgia
The current trend appears to be for lenses that are extremely sharp across the frame, even wide open, with out-of-focus rendering to match. That's fine - I'm not criticising that. But older, simpler lens designs are generally more variable across the aperture range, especially wide open, and typically display more chromatic aberration and other optical imperfections than lenses designed to excel with the latest and greatest digital cameras. They have fewer elements and are smaller, lighter and less expensive as a result.
Originally posted by Rico Change it to WR then.
Potentially more difficult than you think, since this would almost certainly require significant component re-design to make body parts mate together in a weather resistant manner, and to support the addition of WR seals.
Here's the thing... with the exception of optical coatings, focus ring texturing, external finish and labelling, the new HD FA35/2 is - I'm willing to bet -
identical in design and construction to the old FA35/2. It required almost no changes in fundamental design and tooling to produce. It was, I'd suggest, merely a way for Ricoh to continue production of a popular existing lens, leveraging modern optical coatings (because they're both
available and advantageous), and improving its usability and appearance along the way. A low cost way of extending the life of an existing product, whilst offering a few advances in coating technology and operability / aesthetic appeal. This is largely confirmed by the retail price, and the fact that it didn't appear on the road-map.
Originally posted by Rico Some folks may like the personality of nostalgia film era lenses but what Ricoh/Pentax needs to due is produce lenses for the digital age with the personality they are capable of delivering sans the no longer needed aperture ring add QuickShift focus modern lens coatings.
You keep mentioning nostalgia... but it's not about "harking back to the good old days" as that term suggests. Some folks just like the way older lenses render. That doesn't mean they're nostalgic about "the way things used to be". They're not trying to "recapture their lost youth". They just have a preference or tolerance for rendering that's different to others. Even if some of them don't, a number of those certainly have a preference or tolerance for paying under $500 instead of $1000+ to get a fast 35mm "full frame" lens.
With respect, what Ricoh / Pentax
needs to produce is products that folks will
buy in sufficient numbers to make them
profitable. Nothing more, nothing less. What you and I individually
think it should or would
like it to produce is basically irrelevant, unless it's backed by a large majority of other users. So, it might be preferable to
you that Ricoh produces an all-new Pentax DFA35/2 with quick-shift manual focus, no aperture ring and an associated uplift in price. But that doesn't speak for the majority... not until those opinions are harvested, at least. Right now, Ricoh is merely extending the life-span of an existing product with a mild refresh... and why not?
